Oven Range Hookup - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 09:39 PM   #1
Rewards Points: 123
Oven Range hookup
The new range I would like to purchase requires a 40amp circut but I have a 50amp. Can I hookup this range to the 50amp?
Also the wiring is coming from the wall, not connected to an oulet. What would be the cost to install a 3 prong oulet?
jerome8283 is offline   Reply With Quote
Old 11-13-2008, 10:21 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
If the current wire is capable of 50amp service(6gage), then you can always run less on it.
Cost to wire an outlet? Are you going to wire this yourself or are you asking for a cost to hire someone to do it?
It costs about $10 for a plug if your going to wire it yourself. It's something you want to make sure is done properly, so if this is out of your comfort zone, you may want to get some help.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-14-2008, 12:00 PM   #3
Rewards Points: 126
Just swap the 50 amp breaker for a 40 amp. You should have #6 wire installed and existing. Make sure you use a 4 wire receptacle, one that matches you new range cord. 2-hots 1-neutral and 1 ground.
Old 11-14-2008, 12:35 PM   #4
Rewards Points: 123
I ended up installing 4’s and switched the 50 to 40amp. Thanks all!
Oven Building sinr98 Electrical 3 09-13-2008 11:43 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 12:14 AM
New Range Wiring c086473 Electrical 4 03-11-2008 08:50 PM
Dual Fuel Range Elec Hookup Qman Electrical 2 11-28-2007 08:22 AM
