Oven Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 11:13 PM   #1
Oven installation
I have a 4 wire oven and 4 wires from the homerun is it electrically safe if I put the grounding together and have it grounded to the junction box or should I just connect the groundings together and put a wire cap on it or are either of those fine?
Smetanka25 is offline   Reply With Quote
Old 12-27-2012, 11:14 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If the junction box is metal it is required to be bonded.
The Following User Says Thank You to k_buz For This Useful Post:
NJMarine (12-28-2012)
Old 12-28-2012, 08:15 AM   #3
So it's required to be grounded to the box?
Old 12-28-2012, 12:32 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,864
The box is required to be grounded. The oven is also required to be grounded. So both the oven and the box need to be connected to the grounding conductor.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 12-28-2012, 07:24 PM   #5
Rewards Points: 332
Pigtail to the metal box. One end screwed to the box, the other wire nutted to the two other ground wires.
sgip2000 is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
Clearance for double oven installation Steeler99 Building & Construction 1 01-30-2011 06:16 PM
oven installation captainmorgan Electrical 32 03-12-2009 08:42 PM
non-metal conduit for oven installation? Jeremy Hillary Boob, PhD Electrical 0 01-22-2009 11:20 AM
