Oven - 230v - Disconnect? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2010, 10:19 AM   #1
Oven - 230v - disconnect?
I'm installing a new wall oven into a new cabinet.
Previous oven was wired with just the wire nuts exposed behind the oven; I was a bit surprised of not having an electrical box.
I was planning on just installing the correct size electrical box but I've also read that a disconnect is recommended for a 220 appliance if the panel is more than 50' or out of line-of-site (both apply).
This is a wall oven where obviously the connection will be concealed behind the oven.
- Just use an electrical box as normal and per mfg instructions?
- Is it wise / better to use a fused AC Disconnect?
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I've never used a disconnect but appears to be pretty straight forward and inexpensive.
Just want to do correctly
Original connection:
(They did at least have electrical tape around the nuts - this pic is for the new temporarily hooked up for a performance check)
CZSteve is offline   Reply With Quote
Old 06-13-2010, 05:26 PM   #2
Rewards Points: 1,512
I would go with an ordinary electrical box with no switch.
Old 06-13-2010, 05:56 PM   #3
dSilanskas's Avatar
All you need is a 4" Square deep metal box with blank plate and your all set
dSilanskas is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Oven Blew Up at Connector with Element cynthiap Appliances 6 10-31-2015 09:48 AM
Oven Install and Replacement- Dacor $400 CostcoMan Appliances 1 05-24-2010 06:02 AM
30A Air Conditioner Disconnect JPWMU Electrical 6 04-19-2010 03:55 PM
Gas oven problems gregsmy Appliances 1 12-03-2009 05:55 AM
