Outside Water Spigot Has Electrical Current - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 08:49 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by mpoulton View Post
4V is not perceptible except under extraordinary circumstances. Whatever you felt, if it was as you described, was not a 4V shock. Your measurement may not have been between the correct reference points.
You ever feel how painful a 4 volt shock is getting out of a pool?
Old 06-21-2012, 08:51 PM   #17
E2 Electrician
Originally Posted by Standav View Post
I shut off the main and was still getting a reading of about 3.5 volts. What's this mean?
The voltage is unrelated to anything inside your home. Could be a bad/failing primary neutral conductor... call your utility company.
Old 06-21-2012, 08:52 PM   #18
E2 Electrician
If he stuck his meter on a spigot and the earth, and read 4 volts, then something is wrong.
This picture was taken from a job a troubleshooted awhile back, after further testing, this street had a underground primary concentric neutral that was failing, a little boy was shocked at the spigot, hence why we were called.... again, this is a very serious issue.
Old 06-21-2012, 11:17 PM   #19
dmxtothemax's Avatar
Rewards Points: 5,152
It is time to call POCO.
they can check out there system,
It looks like a problem external to your system.
dmxtothemax is offline   Reply With Quote
Old 06-22-2012, 05:06 AM   #20
Rewards Points: 3,256
This was from a job a troubleshooted awhile back, after further testing, this street had a underground primary concentric neutral that was failing, a little boy was shocked at the spigot, hence why we were called.... again, this is a very serious issue.
Am I seeing 2 metal probes sticking out of the red lead?
zappa is offline   Reply With Quote
Old 06-22-2012, 05:53 AM   #21
E2 Electrician
I was using two meters at once to ensure a reliable reading.
Old 06-22-2012, 08:16 AM   #22
Oh good.....I was thinking I had to upgrade my leads to have the latest and greatest.
The Following User Says Thank You to zappa For This Useful Post:
mpoulton (06-22-2012)
Old 06-28-2012, 02:04 PM   #23
So the energy company came out ad said everything is fine from their side. His recommendation is to call the phone and cable companies. He said its only a few volts.
Standav is offline   Reply With Quote
Old 06-28-2012, 02:13 PM   #24
Rewards Points: 266
I can find potential difference anywhere I want with a high impedance volt meter like that.
ionized is offline   Reply With Quote
Old 06-28-2012, 04:12 PM   #25
E2 Electrician
To answer your question, I felt the energize when unhooking the hose. Not a strong shock, but the "buzzing" feeling that makes you want to let go.
Im sure, but we obviously have an issue here....
Old 06-28-2012, 04:14 PM   #26
E2 Electrician
Power companies always suck at first, and to make a blunt comment like that is just crazy talk.... He is uneducated in what to do. Check out the picture I posted with 6 volts at the spigot, funny how it became a million dollar job as they had to dig up the entire street and replace the degraded neutral connector...
One thing you could do is see if your neighbors spigots have the same reading, then get them to call and complain as well...
Old 06-28-2012, 05:53 PM   #27
Doesn't it seem odd that the consensus is an outside source but only one of three spigots is affected?
Evstarr is offline   Reply With Quote
Old 06-28-2012, 05:58 PM   #28
E2 Electrician
Nope, the other two could be supplied by plastic plumbing.
Old 06-28-2012, 06:04 PM   #29
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
I had a hot tub to troubleshoot one time.
12v to ground from the pad.
I turned the main off and the voltage was still there.
Called the poco while I was there, and they came opened the transformer and found nothing.
Underground service with outside disco.
Lady called me back a couple days later, the ground was freshly dug, a poco lock on the customer side of the diso, and the voltage to the pad gone.
To this day, i still don't know what they did.
Old 06-28-2012, 06:05 PM   #30
E2 Electrician
They replaced the neutral conductor...
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
