#1 |
Outside sockets on the same ring?
is it possible to put 4 outside sockets on the same ring as the internal sockets? or do they need to be seperate?
Consumer Units is RCD'd btw.. |
#2 |
Long-Time DIYer
Mark, where you from?
(I'm not a pro electrician, just a long-time DIYer.) Here, "rings" are usually referred to as circuits and "sockets" are usually referred to as receptacles. In any case, outside receptacles are required to be Ground Fault Circuit Interrupted or GFCI to avoid electrocution. In most places, yes they can be on the same circuit as some interior receptacles, as long as the exterior are GFCI. A pro can explain better than me. Good Luck! Mike |
#3 |
Licensed Electrical Cont.
He is in the UK.
Hopefully someone from over there will be around to help.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
| Display Modes | |
| Removing compression ring? | ruzz | Plumbing | 30 | 10-01-2011 07:14 PM |
| Which is better? WAX or Non-Wax toilet ring? | KUIPORNG | Plumbing | 15 | 02-20-2008 03:23 AM |
| Need cost advice for wall sockets | BuyingAClue | Electrical | 4 | 12-13-2006 07:00 AM |
| new sockets | seanie | Electrical | 1 | 08-20-2006 07:07 PM |
| closet flange wax ring problem | elkmo | Plumbing | 2 | 01-14-2006 03:30 PM |
