Outside RV Outlet Box To House Flex Ok? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 12:36 PM   #16
Rewards Points: 330
yeah!!did not see drawing,but for 18"i would just put a box on side of house.he is making a mountain out of a mole hill!!or just run uf all the way and be done with it.
oleguy74 is offline   Reply With Quote
Old 03-11-2011, 07:46 PM   #17
One guy said i did it wrong and i didnt lsiten to to others advise...at that time i had only been told what i could NOT do..which i was thankful for. If one read my last psot i said i dumped the whole outside box. the nipple was only 2"long and just enough to get through the walland stucco and have enough threading for the edge cover. the Romex sheathing stopped right where it enters the nipple so wiers proteced and no sheathing to get hot in conduit. AS far as spacether was plenty space on side but that 10gauge solid is a ***** to bend in circles to allow the 6". suprising how different from 12 gauge.
The reason I was wanting the box outisde was to keep with my story of temporary power..better off just letting it look professional and simple
1488rob is offline   Reply With Quote
Old 03-11-2011, 11:36 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you cannot strip NM and use it in conduit, period.
So, what do you have intentions now for the install? Why don't you describe what you intend on doing and we'll try to help you do a better install and make sure it is code compliant.
Old 03-12-2011, 11:50 AM   #19
Rewards Points: 130
Originally Posted by oleguy74 View Post
you can run nm in a short nipple to transition from inside to out.in fact when nm is used to run power to kit island,it goes in conduit.it is done all the time.read 334.15(b)
What does a kitchen island have to with a box mounted on a wall outside?
If you read my post, I told him he could go through the wall into the back of the box with NM without a nipple. But no further.
Read my post. Your suggestion is EXACTLY what I suggested.
Old 03-12-2011, 12:25 PM   #20
Rewards Points: 330
the ref to kit island was to the answer that no romex in conduit.just a point.i would put a short nipple in the box.wire will be stapled to stud so clamp not nessarly needed.
Old 03-12-2011, 01:43 PM   #21
nap
You talking to me?
nap's Avatar
JV said:
No Romex outside in conduit.
with "outside" being the operative word here.
While Lyons may have been referring to any NM in conduit and if so confused the situation, the fact is; JV and the entire post other than that, if applicable, was addressing NM in conduit outside.
Old 03-12-2011, 02:38 PM   #22
Rewards Points: 330
OK!just did not read J V's post before.went back and read it...
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 05:38 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
