Outside Power Outlets (three Of Them) And Front Yard Light Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 11:37 AM   #1
Outside power outlets (three of them) and front yard light not working
Our three power outlets and the front yard light (which automatically truns on and off) are not working. I checked all GFIs but the problem is still there. I don't see GFI outlet in the garage. What would be the problem?
Davekebe is offline   Reply With Quote
Old 10-30-2011, 11:52 AM   #2
If it is not a tripped GFCI, I would start by checking the breaker panel. Do you know what (if anything else) is on the same circuit? It's possible that either the breaker has tripped, or you have a loose connection somewhere in that circuit.
clashley is offline   Reply With Quote
Old 10-30-2011, 02:55 PM   #3
biggles's Avatar
did you check from the hot side to neutral or ground....something is missing...run an extension cord out there and check its hot to ground and definitly the neutral on each socket.....do the outlets go out with the lights? if the neutrals are wire nuted together might be loose...from the panel
Old 10-30-2011, 03:07 PM   #4
Check *all* GFCI outlets everywhere. Backyard, side of house, bathroom, kitchen, basement, attic, etc. Press reset on each.
And of course all circuit breakers. Push them all to on. When tripped, they may look like they are on. If one moves a bit when pushed to on, turn it off, then on to reset it.
Billy_Bob is offline   Reply With Quote
