Outside Outlets Won't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 07-30-2011, 06:54 PM   #1
Hello readers. I am an idiot, and while I was using my electrical hedge trimmer, I accidentally got the wire caught in the hedge trimmer. I immediately turned the trimmer off when i saw sparks, but now none of the outdoor outlets work. I have tried flipping all the breakers, including the main, and nothing seems to be working. My guess is that the incident caused a power surge. Any other suggestions? Or is an electrician necessary?
bigpimpin91 is offline   Reply With Quote
Old 07-30-2011, 07:10 PM   #2
Sparky
Rewards Points: 510
there is a GFI Receptacle somewhere tripped, could be in the garage or if the house is old enough any bathroom
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
oh'mike (07-30-2011)
Old 07-30-2011, 07:14 PM   #3
DIY staff
Rewards Points: 7,174
If nome of the breakers has a push button (gfi breaker)---Look the house over---the outside outlets are likely wire into a gfci outlet.
Old 07-31-2011, 08:08 AM   #4
Rewards Points: 1,216
Believe me you are not the only idiot around for cutting the cord, my dad always said watch out for the cord, well I did and cut it every time I cut the hedges. Guess what? That's one job I got out of but still had many others. Look for GFI breaker or outlet somewhere that needs to be reset.
COLDIRON is offline   Reply With Quote
Tags
electrician , fuses , outdoor , outlets , power surge
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 08:14 PM
Outdoor outlets don't work john620 Electrical 6 07-25-2011 03:08 PM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 08:07 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 08:28 PM
Outlets Work - Switches Do Not? Quick Electrical 6 08-13-2008 05:10 PM
