Old 12-07-2011, 09:47 PM   #1
Outside outlets not working
My outside outlets are not working. I reset at the GFI which is located in the garage, but once I plug my christmas lights in it trips the GFI. I even tried them one by one and same result. I plugged my electric razor in, did not trip outlet, but no power.
Help
jalston is offline   Reply With Quote
Old 12-07-2011, 09:54 PM   #2
Licensed electrician
You have just found your problem. Something is wrong with your lights. You can confirm this by plugging them into another GFI protected receptacle.
Old 12-07-2011, 11:19 PM   #3
Electromagician
oh, and you need a new razor.
powerfactor is offline   Reply With Quote
Old 12-07-2011, 11:50 PM   #4
Ii just re-read that you don't have power at the receptacle. You might still have a GFI that you have not found.
Old 12-08-2011, 06:17 AM   #5
Christmas lights trip the GFCI. Razor or other devices don't work.
Check the neutral for loose connection somewhere in the daisy chain back to the panel. (There is still a problem with the Christmas light strings.)
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 12-08-2011, 06:30 AM   #6
Super Moderator
Also possible that there is a gfi breaker in the panel---look at your box---
Old 12-08-2011, 11:52 AM   #7
seansy59's Avatar
With the power off at the breaker going to the outlet(s).
Check you connections in the outlet.
Press test THEN reset on the GFCI.
Check for other GFCI's on the circuit, and other loose connections on that circuit. (With power off)
If you can't trace down the breaker for the outlet you are working on, turn off your MAIN breaker. Yes, sounds rediculous, but better rediculous then deep fried.
seansy59 is offline   Reply With Quote
Outside power outlets (three of them) and front yard light not working Davekebe Electrical 3 10-30-2011 04:07 PM
Light switches not working but outlets are Jennybird Electrical 4 11-04-2010 11:15 AM
some outlets not working Clallen Electrical 5 06-08-2009 05:09 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 08:28 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 02:08 PM
