Outside Outlet Stopped Working - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2008, 04:58 PM   #1
Outside outlet stopped working
Outside outlet used only for x-mas lights the past week just suddenly quit working. Tested the receptacle...and open wires around it and nothing seems to be getting juice. ALL circuit breakers fine and all other outlets seem to be fine that are near this one...but inside the house.
ANY SUGGESTIONS???
mclontz is offline   Reply With Quote
Old 12-10-2008, 05:01 PM   #2
Check for some gfcis in your house, try to test and reset them. I recommend looking in the bathrooms gfcis first.
If that fails, you need to trace the circuit for splices, could be a bad splice, but is most likely a gfci.
rgsgww is offline   Reply With Quote
Old 12-10-2008, 05:10 PM   #3
joed's Avatar
Rewards Points: 13,298
Look in garage for GFCI also. Usually found behind the pile stuff that hasn't moved in years or behind the beer fridge.
Old 12-10-2008, 05:11 PM   #4
Only 1 gfcis in the house...upstairs...reset it...Didn't help
Old 12-10-2008, 05:14 PM   #5
Do you know which breaker powers this outlet?
How are you testing for power?
Old 12-10-2008, 05:14 PM   #6
I pulled the receptacle out from the wall....all the wires seem to be attached ok. But when it was tested...NO JUICE at all.
Old 12-10-2008, 05:16 PM   #7
Not all connections may be dead.
Check for volts from the short slot (hot) to ground (e.g., the soil near the outlet).
Check for volts first, between the long slot (neutral) and between the ground hole and ground. If no volts, and there shouldn't be, then check for ohms to ground from the slot and ohms to ground from the ground hole.
If both hot and neutral are both open it could be an upstream GFI.
How do you know that resetting the GFI actually restored power?
Old 12-10-2008, 05:19 PM   #8
Tested with multimeter ...no voltage at all..
Old 12-10-2008, 05:20 PM   #9
Recycled all breakers just to make sure...no help there either
Old 12-10-2008, 05:22 PM   #10
There is an inside plug immediately behind the outside one that works....Would this one be on the same circuit??...we assume it is
Old 12-10-2008, 05:22 PM   #11
Try what yoyizit said. If there no resistance reading from white to ground, and no volts from black to ground then a gfci must have tripped.
Find the breaker to that outlet and turn power off, open the outlet. Whats inside?
Old 12-10-2008, 05:33 PM   #12
THANKS!!...Found a gfci that was hidden behind a towel rack in the master bathroom near the shower...FIXED THE PROBLEM!!!
Thanks a million guys....ABSOLUTE LIFESAVERS!!!
Old 12-11-2008, 07:11 AM   #13
Rewards Points: 900
Keep in mind that your GFCI tripped for a very good reason. There was current flowing from hot to ground, most likely outside. You need to make sure all outdoor receptacles and connections are properly protected from the weather.
Never, ever defeat the GFCI. It will save your life!!
Ultrarunner2017 is offline   Reply With Quote
Old 12-11-2008, 09:37 AM   #14
Except when it's not (nuisance tripping, false positives).
Whirlpool Icemaker Stopped Working jablizz General DIY Discussions 1 07-19-2008 08:38 PM
Outlet stopped working nealt Electrical 9 07-19-2008 03:46 PM
Outlet not working? Madnpc Electrical 3 12-07-2007 05:51 PM
Outlet in garage quit working Thirdeye Electrical 10 07-01-2007 10:32 PM
Light Stopped Working gershon Electrical 5 01-10-2007 08:03 PM
