Old 08-01-2007, 05:11 PM   #1
outside outlet
I would like to put a new outside outlet on my house. I have two allready, one on the north side and one on the south side, but I would like to put one on the west side. Would this be hard to do? The west side of the house is where my power comes in, so the breaker box is right there. Could I add a new circuit breaker, cut a hole in the wall, and add the new outlet?
windshield_king is offline   Reply With Quote
Old 08-01-2007, 05:24 PM   #2
Master Electrician
JohnJ0906's Avatar
outside outlet
Yes. With the box right there, it shoud be fairly simple.
Outlet must be GFCI protected, either GFCI receptacle or breaker.
Weatherproof cover. If you might be leaving something plugged in, use an "In use" or "Bubble" cover.
Before you cut any holes it the wall, check inside very carefully. Cutting into wires, pipes, etc. is considered bad form!
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 08-01-2007, 05:49 PM   #3
outside outlet
thank you, I would be using it for some low voltage lighting.
Old 08-01-2007, 09:40 PM   #4
Master Electrician
JohnJ0906's Avatar
outside outlet
You will want to use a bubble type cover, it is made to close over the outlet with something plugged in.
John from Baltimore
One Day at a Time
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 09:18 PM
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 09:22 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
