Outside Lights Turning Off After 20 Seconds - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 08:51 PM   #1
Outside lights turning off after 20 seconds
So I went out to Home Depot and bought some lights to replace the old ones we had that worked fine. I installed all the lights hit the power and everything worked fine that is until 20 seconds passed. The lights flickered and turned off. I checked the breaker box and none of the breakers had tripped. I took all the lights down and rewired one at a time. No dice all had the same result. Once the light turns off on its own it wont turn on again until I rewire it then it turns on for 20 seconds and back off again. I checked all the wiring to make sure live parts of the wires weren't touching. I'm a little concerned that the breaker hadn't tripped. Anyone have any ideas?
vdubplate is offline   Reply With Quote
Old 09-30-2012, 08:57 PM   #2
Electrical Contractor
kbsparky's Avatar
Ummm ... maybe you installed a fixture with a photocell unit, and it shuts itself off because it's still daylight when you switched it on?
Have you tried to use it after dark?
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Code05 (09-30-2012)
Old 09-30-2012, 11:39 PM   #3
Rewards Points: 506
or, temporarily put some black tape around the photocell?
Old 10-01-2012, 02:01 AM   #4
Rewards Points: 438
Haven't you heard, that's the latest energy saving concept.
Old 10-01-2012, 02:12 AM   #5
I wish that was the the answer to my problem. I went back and tried to reinstall the old lighting and that wouldn't work either. These are the lights we bought:
http://www.homedepot.com/Lighting-Fa...specifications
Old 10-01-2012, 05:13 AM   #6
kbsparky's Avatar
Bad wall switch. Replace it next.
-KB
Air Handler Blower runs for 20 seconds then stops for 3 seconds JohnRoss HVAC 13 02-12-2016 10:53 AM
Lights still dimming and flickerin Keisha34 Electrical 18 06-09-2012 12:14 AM
adding lights mharwell01 Electrical 1 01-03-2009 04:59 PM
Rheem Criterion lights, but only runs for 30 seconds max... all4naught HVAC 2 12-26-2008 08:36 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 10:55 AM
