Outside Lights Are Dim All The Time. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 11:04 PM   #31
Rewards Points: 12
I had to cut a hole on top of the first light fixture box and dig out a little insulation then pulled the switch wire that went to the second light up out of the switch box and stuck it in the first light box and hooked it all up and it worked fine. Now it's wired like this.
hendo3 is offline   Reply With Quote
The Following User Says Thank You to hendo3 For This Useful Post:
jbfan (02-05-2013)
Old 02-07-2013, 05:52 AM   #32
dmxtothemax's Avatar
Rewards Points: 5,098
Originally Posted by hendo3 View Post
This is how it's wired and its in wet cellulose insulation so any suggestions.
If this is how its wired ?
its wrong !
And in series, like everyone was telling you !
Please explain how you fixed it ?
dmxtothemax is offline   Reply With Quote
Old 02-07-2013, 09:15 AM   #33
Rewards Points: 1,418
The diagram in reply #31 as of Feb. 7 9 AM is correct.
The diagram in reply #26 as of Feb. 7 9 AM does not give enough detail to indicate a series versus a parallel circuit but does give enough information to reveal the original problem, one light stays on when the switch is flipped off.
The wet cellulose situation is a separate topic that needs to be addressed and fixed (the moisture eliminated).
wire diagram for pot ceiling lights Dan thehandyman Electrical 12 02-24-2012 11:30 AM
Lights take long time to turn on clouts69 Electrical 8 12-17-2009 06:53 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 09:35 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
