Outside Lights Are Dim All The Time. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 10:23 PM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If you are wired the way your diagram shows the lights should function properly. I suspect your power is entering a light fixture box first and them goes to the switch ...
So where does incoming power enter you lighting circuit ? At a light fixture box or at the switch
Old 02-04-2013, 10:27 PM   #17
Rewards Points: 12
Power comes in through the switch. At first in the first light I had the white of the light to the white of the switch and the black of the light to the white of the second light with the black power and the black of the second light together and the light worked properly but they were dim so I hooked it up like the pic shows and now the first one won't turn off
hendo3 is offline   Reply With Quote
Old 02-04-2013, 11:04 PM   #18
UAW SKILLED TRADES
Stubbie's Avatar
You stated you wired your entire house ...
I have no idea what you mean by white of the light to white of the switch.
What wires are connected to your switch now?
Old 02-04-2013, 11:11 PM   #19
Rewards Points: 12
The switch has been wired like in the picture I posted earlier the whole time. I just don't understand what would cause one light to stay on and the other to work properly.
Old 02-04-2013, 11:24 PM   #20
UAW SKILLED TRADES
Stubbie's Avatar
Only way we can help you at this point is to post pictures of all your wiring in the boxes so we can see clearly the connections.
The Following User Says Thank You to Stubbie For This Useful Post:
jbfan (02-05-2013)
Old 02-05-2013, 07:53 AM   #21
Rewards Points: 1,512
Power comes in through the switch. At first in the first light I had the white of the light to the white coming from the switch box and the black of the light to the white of the second light with the black power and the black of the second light together and the light worked properly but they were dim so
This is the one with two or more lights connected in series which is a no-no in household wiring.
Hint to avoid accidentally connecting lights in series: Match the wires colors. Normally you connect white to white only and connect black to black only. One allowable exception; white may go from a switch terminal to the always hot black wire or group of black wires if no other wire is available. (Colors other than green or white can be freely interconnected.)
The diagram that you posted (@12:01 AM 2/5/13) is correct.
Does the switch have a toggle that lights up (for nighttime convenience) when the switch is off? That will cause current to (intentionally) bleed through but can (unintentionally) cause a light to come on although usually much more dimly.
Old 02-05-2013, 05:13 PM   #22
Rewards Points: 12
The first with the lights is the switch on the second the switch is off.
Outside lights are dim all the time.-image-1704106636.jpg   Outside lights are dim all the time.-image-1180099868.jpg   Outside lights are dim all the time.-image-1938335867.jpg   Outside lights are dim all the time.-image-4218596264.jpg
Old 02-05-2013, 05:22 PM   #23
Rewards Points: 34
The switch box has two neutrals tied together. Is one missing or is the other switch on a different circuit?
djlandkpl is offline   Reply With Quote
Old 02-05-2013, 05:27 PM   #24
Rewards Points: 12
There is only one switch that runs the lights. So those white wires in the switch box are the switch and power.
Old 02-05-2013, 06:24 PM   #25
Rewards Points: 12
I figured out why the first light is staying on. From the switch I have 2 switch wires one going to each light. And the power comes into the first light. Anyone know how I can fix this
Old 02-05-2013, 06:47 PM   #26
Rewards Points: 12
This is how it's wired and its in wet cellulose insulation so any suggestions.
Old 02-05-2013, 07:04 PM   #27
langless28's Avatar
Rewards Points: 152
Is it cold where you are? Fluorescent bulbs do not work as well in the cold. They take a lot longer to reach full brightness.
langless28 is offline   Reply With Quote
Old 02-05-2013, 09:05 PM   #28
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
No way to do it without another wire from the first light to the switch!
jbfan is online now   Reply With Quote
Old 02-05-2013, 09:06 PM   #29
Rewards Points: 12
Thanks to all that replied I fixed the problem they work fine now.
Old 02-05-2013, 09:35 PM   #30
jbfan's Avatar
Rewards Points: 478
Do you mind telling us how you fixed it?
wire diagram for pot ceiling lights Dan thehandyman Electrical 12 02-24-2012 10:30 AM
Lights take long time to turn on clouts69 Electrical 8 12-17-2009 05:53 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 11:22 AM
