Outside Lights Are Dim All The Time. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2013, 08:29 PM   #1
Rewards Points: 12
Outside lights are dim all the time.
I have my outside lights hooked up and they are always dim. The power comes up from an outlet to the switch then to the lights. All the outlets on the circuit work fine so I don't understand why the lights are dim. I even put up different light fixtures and i have tried different light bulbs and i get the same result. Can anyone help me fix this problem.
hendo3 is offline   Reply With Quote
Old 02-04-2013, 08:34 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What type of lamps are you using?
Old 02-04-2013, 08:44 PM   #3
Check to see if the wiring to the fixtures are hooded up in series instead of parallel. Two fixture in series, each fixture would only received 60 vac instead of 120 vac.
tgray1 is offline   Reply With Quote
Old 02-04-2013, 08:47 PM   #4
Floresant bulbs
Old 02-04-2013, 08:51 PM   #5
deverson's Avatar
Rewards Points: 77
Does the light switch have " on off" on the handle? If not maybe a dimmer switch is installed somewhere else and is dimmed. Could be a 3way circuit.
deverson is offline   Reply With Quote
Old 02-04-2013, 08:54 PM   #6
Rewards Points: 12
They are wall lamp porch lights. I've tried regular 100 watt bulbs and the energy saver mini twister bulbs.
Old 02-04-2013, 09:02 PM   #7
Rewards Points: 12
How do I know if they are hooked up in a series or not. What do I look for.
Old 02-04-2013, 09:58 PM   #8
Rewards Points: 1,442
Did you install and hook up the lights and wiring yourself?
Series wiring -- Hot wire connected only to one wire of one light fixture. Other wire of that light fixture connects only to ongoing line to next fixture. At next fixture line from previous fixture connects to one wire of fxture. Other wire of fixture goes to continuation to yet another fixture. Never done in household wiring for multiple light fixtures but may be found in some laboratory test equipment for light bulbs.
Parallel circuit -- Hot wire (black) connected to black fixture wire and also to black wire of cable continuing to next light. Neutral wire (white) connected to white fixture wire and also to white wire of cable continuing to next light, as separate bundle from black wires. Same at next fixture.
Note that a switch is connected in series with the light it controls (or in series with a group of parallel connected lights. With power feed cable with hot and neutral entering the box, the hot wire (black) is connected to one terminal on switch. Other terminal on switch connected to black wire of cable going to the light(s). In the switch box the white wires are connected to each other and not to the switch. (Different rules for switch box with only one cable.)
Old 02-04-2013, 10:07 PM   #9
Rewards Points: 12
Ok I fixed the dim part but now the first light stays on when I shut the switch off but the second shuts off. This is how I did it.
Old 02-04-2013, 10:07 PM   #10
dmxtothemax's Avatar
Rewards Points: 5,102
Have you put a voltmeter on the fitting to read the voltage ?
Can you do so ?
Could be wrong wiring, loose / bad connecttion, faulty cable.
Voltage please ?
dmxtothemax is offline   Reply With Quote
Old 02-04-2013, 10:30 PM   #11
Rewards Points: 12
What would cause the first light to stay on all the time but the second light will shut off and turn on with the switch
Old 02-04-2013, 10:59 PM   #12
Wrong wiring !
Most likely in series !
Can you post a pic of the wiring ?
Or even draw a diagram ?
What color wires go where ?
Old 02-04-2013, 11:04 PM   #13
Rewards Points: 12
I already posted a pic of the way I have it wired now. I tried it another way and both lights worked properly but they were dim. So it has me confused. I wired my whole house myself and this is the only place I have this problem.
Old 02-04-2013, 11:15 PM   #14
Maybe you had two problems ? not just one !
If they both switch on properly.
Next step is to check what voltages are where.
Can you measure at switch and at each lamp base ?
Old 02-04-2013, 11:15 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
If you have them wired the way you show, then it will work correctly.
You have to have it miss wired.
jbfan is online now   Reply With Quote
wire diagram for pot ceiling lights Dan thehandyman Electrical 12 02-24-2012 11:30 AM
Lights take long time to turn on clouts69 Electrical 8 12-17-2009 06:53 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 09:35 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
