Outside Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 07:42 PM   #1
Question
outside lights
I'm having vinyl siding put on my house and would like to remove the outside lights. Can anyone tell me what to do to the wires (clamp? ...) to make them neutral (other than shutting the circuit) while the work is being done?
Thank you.
Darlene
dprejean is offline   Reply With Quote
Old 06-28-2009, 09:13 PM   #2
The installer isn't handling this?
Remove permantly ?
Clamp the wires - ?? What do you mean?
Usually you put a wire nut on the individual wires (when the breaker is off)
Old 06-28-2009, 09:49 PM   #3
2 fingered typer
woodnthings's Avatar
Shut of the breaker to the Outside Lights!
And do not work with an aluminum, ladder, or allow anyone else to do so! Put electrical "nuts" on the bare wires, do not twist wires together that were not already together, keep each wire separated and nutted. Tape over the breaker in the off position and note that it is shut off. When the siding is up return to normal. bill
woodnthings is offline   Reply With Quote
Old 06-29-2009, 12:04 AM   #4
Turn off the switch and cap the bare ends in case someone turns it back on.
220/221 is offline   Reply With Quote
Tags
neutral , outside lights
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 09:35 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
