Outside GFI - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2012, 11:08 PM   #1
Outside GFI
I was wondering if anyone could help me out with a couple things?
The GFI normally by the front and back door,
Question #1- I was wondering if this has to be by code 12/2 -20 Amp breaker or can they be 14/2 -15 Amp Breaker?
Question #2 - Can the front door GFI and the rear door GFI be on the same breaker or is it code they have to be on 2 separate breakers?
Thanks in advance for any help or replies.
-POWER
POWER STROKE is offline   Reply With Quote
Old 08-16-2012, 11:22 PM   #2
Rewards Points: 13,724
If this is new wiring install the GFI inside the house, jump off on the load side to a reguler outlet outside then go from there to the other outlet.
Reason being it will keep the GFI in a dry area and you will get less false trips from moisture.
Old 08-16-2012, 11:24 PM   #3
"So I Re-Wired It"
MisterZ's Avatar
if im not mistakesn they can go on 15 amp breakers. i dont think there is a rule that they need separate circuits either.
they do, however, require the front and rear GFI protected circuits.
i'll need to double check to be sure. meanwhile, someone else will probably give a definitive answer before i get back
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-16-2012, 11:26 PM   #4
Thanks for the help, can that run off the GFI Next to panel or does the GFI by the panel have to be by it self by code?
Old 08-16-2012, 11:32 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You can use the gfi by the panel to protect the outside receptacles
Old 08-16-2012, 11:42 PM   #6
Thanks for the help and reply
Old 08-16-2012, 11:42 PM   #7
Old 08-16-2012, 11:45 PM   #8
"So I Re-Wired It"
MisterZ's Avatar
NEC 2011 code 210.8(A)(3) Outdoors.
doesnt specify dedicated. can use 15 or 20 amp circuit.
Old 08-16-2012, 11:47 PM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
They make WP (weatherproof) GFCI receptacles...
Old 08-16-2012, 11:52 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
Not really ... the same moisture problem exists with the regular receptacle you install outside so therefore the gfci will nuisance trip anyway. If you install the wp gfci as stickboy mentions and use "in use" covers you will not have any problems.
Old 08-16-2012, 11:57 PM   #11
E2 Electrician
I am a big fan on installing GFCI's at point of use, this way you are not hunting down forgotten GFCIs, and you can easily reset the defunct device.
The Following User Says Thank You to stickboy1375 For This Useful Post:
jrclen (08-19-2012)
Old 08-17-2012, 12:05 AM   #12
Thanks everyone for your help and input
Old 08-17-2012, 05:04 AM   #13
Master Electrician
Rewards Points: 3,870
Wouldn't that be weather resistant?
brric is online now   Reply With Quote
Old 08-17-2012, 05:28 AM   #14
E2 Electrician
Yes, correct.
Old 08-17-2012, 08:55 AM   #15
UAW SKILLED TRADES
Stubbie's Avatar
I thought the formula for weather proof was .. (WR) + IN USE COVER = WP
