Outside Garage Lights Won't Work? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2011, 06:46 PM   #1
geg
Outside garage lights won't work?
I have a condo and three lights outside a two car garage have gone out and I don't know why. I have reset all of the GFCI outlets through out the condo and turned all the circuit breakers off and on. None of the circuit breakers were tripped and none of the GFCI outlets needed to be reset. Any thoughts.?
G
geg is offline   Reply With Quote
Old 03-21-2011, 07:44 PM   #2
Pretending to be Retired
Do you have power at the switch? If yes, do you have power at any of the 3 fixtures? On my house, the power leaves the switch, goes to one of the fixtures, then goes to the others. Two of mine were nonfunctional, and I found a broken black wire in the wire nut. So, power would go to the first fixture, but couldn't proceed to the others because of the broken wire. It was a easy fix.
BigD9 is offline   Reply With Quote
Old 03-21-2011, 07:47 PM   #3
Rewards Points: 558
Did you check and see if the lights are burnt out?
epson is offline   Reply With Quote
Old 03-21-2011, 08:38 PM   #4
geg
I did not check the switch. That may be bad. I will test it and check the wires to each light. I did check the lights, they are not burnt out. Thanks, I appreciate the replies.
Old 03-21-2011, 08:40 PM   #5
Rewards Points: 558
How old are these lights? You can also check on the wiring connecting the lights to see if a connection has become lose or damaged.
Garage Door Opener (remote controls won't work) mjkpainting General DIY Discussions 9 01-28-2010 10:03 AM
jenn-air cooktop electric pilot lights do not work puckmen Appliances 1 07-27-2009 08:29 PM
Garage door opener doesn't work iris@sonic.net Electrical 4 09-07-2008 08:08 PM
Hall lights don't work. jagrunner2602 Electrical 13 05-02-2007 11:08 PM
garage lights kelr Electrical 1 06-20-2005 10:31 PM
