Outside Electrical Outlets - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-03-2008, 01:32 PM   #16
Rewards Points: 338
pjm, If it's not to difficult to do (from the attic or basement) I would run a separate 20A circuit for the outside outlets (GFI protected). For the Christmas lights, you might consider controlling them with a switch/timer. This way they don't stay on all night. You can get a "siding adapter" (my term...) made by Arlington http://www.aifittings.com/k_1.htm that will give you a more finished look. They mate to most siding types and provide a flush surface (the big orange store sells them). The switch can be located on the inside in the same bay at the same height as other switches in the house. You will probably also have to use an "in-use" cover on them (allows a plug to be inserted with the cover closed, keeping the outlet weather resistant).
petey_c is offline   Reply With Quote
Old 08-04-2008, 08:59 AM   #17
pjm
thanks petey. I will be running a seperate line from the panel for these new outlets. Can I use one gfci outlet and daisy the other two off of it? Or should I use gfci for each outlet? I guess it would save me a few bucks to daisy them, but I could do it either way. And I will be using timer's on my Christmas lights for sure.
Thanks.
pjm is offline   Reply With Quote
Old 08-04-2008, 12:25 PM   #18
Rewards Points: 508
Send a message via AIM to theatretch85
You can do the GFCI protection however you want, GFCI breaker, GFCI outlet and daisy chain the rest as standard outlets, or GFCI outlets in each location. I have been told its not a good idea to use both a GFCI circuit breaker and a GFCI outlet on the same circuit. Something about tends to cause nuisance tripping of either one of the GFI's. Personally, if the outlets are not located near each other and are in different areas (front and back of house) I would wire a single cable to each outlet (saves some on wire run, esp with the price of copper) and if one GFI trips you don't need to go to the other side of the house to reset it. I think I have seen 3 packs of GFI outlets for like 15-20 bucks, which is pretty reasonable considering how much they used to cost.
theatretch85 is offline   Reply With Quote
Old 08-04-2008, 01:03 PM   #19
Ash
Send a message via MSN to Ash
Does the RCD socket have long life when exposed to weather ? Maybe its better to put an RCD inside the house and simple sockets out
Ash is offline   Reply With Quote
Old 08-04-2008, 01:16 PM   #20
Rewards Points: 508
This is why a "Wet Location While In Use" cover is used in this situation, protects the outlet while also allowing a cord to be plugged in at the same time. I believe this is a code requirement now, used to be at least a weather resistant cover when not in use. I have a GFCI outlet connected to the bottom of a sub panel in my backyard for a fountain and its been working fine for 4 or 5 years with no issues. Always "test" the outlet every year the fountain is setup. This also has a "wet location while in use" cover on it and works perfectly with the fountain cord plugged in.
Old 08-04-2008, 04:09 PM   #21
pjm
I think I'll go the route of using a seperate gfci outlet for each location as mentioned above it will save me a walk around the house if it trips. So a single 20 amp circut should be good for all three outlets? I just want to do it right the first time and have it pass inspection.
Thanks again for all the help.
Old 08-04-2008, 05:13 PM   #22
Ash
The GFCI is a sensitive device. Maybe it will get destroyed with time from humidity in the air which the standard cover does not block (it is not air tight)
A simple socket does not mind this humidity too much (copper parts get oxidised but they are scratched each time a plug is inserted)
Old 08-04-2008, 05:31 PM   #23
pjm
So you think a GFCI breaker at the panel would be better then use normal outlets in outdoor boxes instead? I could do that just as easily.
Old 08-04-2008, 05:59 PM   #24
Whatever is easier/cheaper to troubleshoot and replace without special test equipment.
http://www.google.com/search?hl=en&q...2+ground+fault
Old 08-04-2008, 06:12 PM   #25
pjm
Wouldn't be replacing it will all be new.
Old 08-04-2008, 07:02 PM   #26
Rewards Points: 508
A GFCI Breaker last I checked was around 50 bucks, and a 3 pack of GFI's were about 15-20 bucks; much cheaper to go the route of the outlets. Like I mentioned earlier, I have had the same GFCI outlet in use in my backyard with a "wet location while in use" cover and in a damp area. Its located next to the air conditioner, which is down below the garden level and also where the pond is located. So I am sure there is plenty of moisture near this GFCI outlet and its worked every time I have tested the GFI before plugging in the pond each summer. So I highly doubt you have much of anything to worry about with the GFCI working properly or being damaged by the climate. Besides, the GFCI outlets are cheaper and easy to replace; and by going the route of the GFCI breaker your back to having to walk to the panel to reset it if something trips the circuit.
Old 08-04-2008, 07:19 PM   #27
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
I have 4 GFCI receptacle outlets on my house with the old type leaky covers. I've replaced one in almost 20 years. I buy Pass Seymour or other name brands. I recommend avoiding the 3 for $20 Chinese units from the big box. To many don't work right out of the box.
John
jrclen is offline   Reply With Quote
Old 08-04-2008, 07:25 PM   #28
I was thinking of "down the road."
The hidden cost of ownership is troubleshooting/replacing [if they need it].
Old 08-04-2008, 07:52 PM   #29
Rewards Points: 508
I haven't actually bought the 3 packs, I have noticed them while in the store though. I am usually only doing one at a time and have never really thought to get the 3 pack. But now that you say that it makes sense that they are cheaper. I think I spent a little bit more money on this GFCI and got the 20 amp outlet (maybe its only 15 amp) but I recall envisioning the need for additional power at this outlet and since its been installed, the only thing its powered is a small pond pump. Yeah, dedicated 20 amp circuit for a simple pond pump, haha.
Old 08-04-2008, 07:56 PM   #30
jrclen's Avatar
Rewards Points: 514
To much power is always better. I use 20's also.
John
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
Electrical storm - outlets not working SG94 Electrical 4 04-27-2008 09:28 AM
Electrical outlets and Granite backsplash, how? section8 Remodeling 6 01-08-2007 06:55 AM
Can a diyer install electrical outlets? yummy mummy Building & Construction 12 12-23-2006 06:54 PM
Electrical outlets and Granite backsplash, how? section8 Electrical 10 07-01-2006 08:53 AM
