Outside Electric Post - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 11:15 PM   #1
outside electric post
DIY outside electric post at dock side
tgirl is offline   Reply With Quote
Old 07-07-2012, 11:31 PM   #2
Master Electrician
use duct tape.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-07-2012, 11:35 PM   #3
Rewards Points: 3,256
Are you serving Margaritas and giving free boat rides? You have to do the work yourself but we can assist if you are not too far away.
zappa is offline   Reply With Quote
Old 07-08-2012, 10:54 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
It can be done!
Old 07-08-2012, 11:01 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Cut 4x4 to desired length. Mount post in ground. Run 6-2 UF w/ground (to account for any voltage drop). Strip the black and white. Staple the stripped white to the bottom of the post. (That way the neutral is bonded with ground). Staple the stripped black to the top of the post. Leave the bare ground in the ground.
Old 07-08-2012, 11:08 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Instead of my typical sarcasm or biting wit I'll choose to ask a serious question.
What kind of help do you expect to get with such a post? It's not even a question, did you think this was a search engine?
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
DangerMouse (07-08-2012), gregzoll (07-08-2012), mpoulton (07-09-2012)
Old 07-08-2012, 03:33 PM   #7
Master Electrician
Rewards Points: 3,678
Aluminum or steel? What voltage? What color? What wattage? How is it controlled? How tall is it?
brric is online now   Reply With Quote
Old 07-08-2012, 03:43 PM   #8
Rewards Points: 1,214
No diy for you call a Electrician.
COLDIRON is offline   Reply With Quote
Old 07-08-2012, 04:03 PM   #9
the Musigician
DangerMouse's Avatar
Thank you. Do you want a job?
DM
Old 07-08-2012, 04:38 PM   #10
Rewards Points: 6,652
Alex, I would like to pick the daily double.
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 10:56 AM
