Outside Distribution Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 05:19 PM   #1
outside distribution box
I have this box on the outside of my house supplying power to different places. It supplies power to the main breaker box inside the house, the detached garage panel, dryer, and an air conditioner circuit. Iím guessing that the pull out thingies have fuses on the back. The connector with the two visible green fuses is marked Ďspareí and has no wires to or from it.
I want to add a new panel in the upstairs of my house. The main circuit breaker in the house just behind this outside box is full. Can install another circuit into this box and make the run to the upstairs? What are the connectors called that I would need to install in this outside box. After all I canít go in and just ask for connector thingies If I add a panel upstairs from this outside box would it be classed as a sub panel or main and would I separate the neutrals and grounds in it? From what I understand it would be a sub panel since this is the first panel after the meter. Correct?
If I install a 100 amp panel but only want to supply 60 amps capacity how do I handle that? Can I simply remove the panels 100 amp breaker and install a 60 amp breaker. Will a standard 60 amp breaker physically fit the removed 100 amp breaker or will I need to install it down on the output lugs and back feed it? The upstairs panel will only handle two baths and three bedrooms plus hall plus a planned gas fired heating unit in the attic. No other appliances so Iím guessing 60 amps and 8 to 12 circuits would be plenty. Most of the upstairs wiring is knob and tube presently which of course is the reason for the upgrade. Is there a better way to go about doing this? Thanks
outside distribution box-outside-view.jpg   outside distribution box-outside-opened.jpg
Last edited by Mike in Arkansas; 08-12-2009 at 08:54 PM. Reason: pics asking to login
Mike in Arkansas is offline   Reply With Quote
Old 08-12-2009, 06:29 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,938
Originally Posted by Mike in Arkansas View Post
I have this box on the outside of my house supplying power to different places. It supplies power to the main breaker box inside the house, the detached garage panel, dryer, and an air conditioner circuit. I’m guessing that the pull out thingies have fuses on the back. The connector with the two visible green fuses is marked ‘spare’ and has no wires to or from it.
I want to add a new panel in the upstairs of my house. The main circuit breaker in the house just behind this outside box is full. Can install another circuit into this box and make the run to the upstairs? What are the connectors called that I would need to install in this outside box. After all I can’t go in and just ask for connector thingies If I add a panel upstairs from this outside box would it be classed as a sub panel or main and would I separate the neutrals and grounds in it? From what I understand it would be a sub panel since this is the first panel after the meter. Correct?
If I install a 100 amp panel but only want to supply 60 amps capacity how do I handle that? Can I simply remove the panels 100 amp breaker and install a 60 amp breaker. Will a standard 60 amp breaker physically fit the removed 100 amp breaker or will I need to install it down on the output lugs and back feed it? The upstairs panel will only handle two baths and three bedrooms plus hall plus a planned gas fired heating unit in the attic. No other appliances so I’m guessing 60 amps and 8 to 12 circuits would be plenty. Most of the upstairs wiring is knob and tube presently which of course is the reason for the upgrade. Is there a better way to go about doing this? Thanks
It sounds like you probably need to upgrade your service. The type of service you describe sounds like an old 60A panel with pull out fuses. I'm surprised it can handle the load that's already on it, and it is unlikely that it can safely or legally handle more. Probably the most economical solution would be to replace your service entrance equipment with a new 200A panel that feeds the existing loads and also includes whatever new circuits you were planning to install. Definitely consult with an electrician.
mpoulton is offline   Reply With Quote
Old 08-12-2009, 06:42 PM   #3
Your pictures were not showing up & have been removed
They were prompting people to login to view
-Dave
Old 08-12-2009, 09:02 PM   #4
My apologies for the pictures. I copied and pasted from a word processor. Should be fixed now. I do have a 200 amp service. It supplies a 100 amp panel just behind the wall which is full, a 60 amp detached garage and a couple of individual circuits.
I have spent quite a bit of time on this forum and have not seen this particular installation. Advice is appreciated help for the original posting. Perhaps a couple of more pictures would be of help. Thanks.
outside distribution box-main-breaker-box-1.jpg   outside distribution box-outdoor-up1.jpg   outside distribution box-outdoor-boxs.jpg   outside distribution box-outside-detail2.jpg
Old 08-12-2009, 09:55 PM   #5
Rewards Points: 2,350
The two screw fuses aren't being used, so you could get a 30 A subfeed from there if you wanted, or two 20 A branch circuits. Also, you could parallel tap one of the fuse blocks and power another panel, but that is quite an advanced topic for DIY. But, the idea is that you would disconnect the lines from the fuse block, and using an insulated tap (trade name: polaris lug), you could wire your old wires and new wires into the same block, and both panels would be powered by the same set of fuses.
You would need to make sure of course that the fuses match the wire size. And you need a four wire feed to the new panel, the grounds and neutrals being seperated at the sub.
Old 08-12-2009, 09:57 PM   #6
Just re-reading, what is in the garage? If there is alot of load there, why not power the garage from the 30 A screw-in fuses and use that 60 A block for your new panel?
Old 08-12-2009, 11:53 PM   #7
That would be a great idea except I have a woodworking shop out there and not sure 30 amps would be sufficient. Can the connectors not be moved to make room for one more somehow. Maybe take out the 30 amp block and replace with a 60 amp. Is there a problem getting these fuse connectors now? A Polaris lug is a splicing block correct? If I paralleled the circuits, say off of the top fuse block that provides power to the main breaker panel, would I just need to put larger fuses in the same fuse block. 160 amp? Or would I need a new larger fuse block? Thanks for taking time to help. Oh yeah, one more question. Since I have a three wire feed coming in how do I provide a fourth wire to a subpanel?
Septic Distribution box holding water Karly&Gerry Plumbing 2 06-05-2009 09:25 AM
Low profile junction box or distribution block for line voltage undercabinet lights ? Bluelude1 Electrical 2 05-01-2008 07:52 PM
Copper pipe type for residential water distribution BigJimmy Plumbing 7 12-31-2007 08:39 AM
load distribution sporthead200369 Building & Construction 1 04-28-2007 08:54 PM
