Outlets And Windows - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 08:34 PM   #1
Rewards Points: 236
outlets and windows
what is the rule when placing outlets close to windows ? i have a window, that is about 30" from a corner. and around that corner is another window about 35".
i need to place an outlet on each wall, between the windows and corner. but this could put the outlets very close to the corner and each other.
what should i do ?
Fix'n it is offline   Reply With Quote
Old 10-22-2012, 08:36 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Within 6' of a doorway, and no more than 12' between receptacles.
jbfan is online now   Reply With Quote
Old 10-22-2012, 08:39 PM   #3
Rewards Points: 13,732
I've been putting them under every window. The ladys love it so they can plug in there Chrismas lights that sit on the window stools.
Old 10-22-2012, 08:43 PM   #4
Licensed electrician
Rewards Points: 1,622
You can add the receptacles where you want them. As long as there is no more than 12' between them you are good.
Old 10-22-2012, 08:52 PM   #5
Pure Genius
Rewards Points: 150
Joe. Sell them on sill-lites.
Dierte is offline   Reply With Quote
Old 10-22-2012, 08:59 PM   #6
Rewards Points: 236
wow. i read on here that they should not go under windows.
i am putting in enough that any device would not need an extension cord.
Old 10-22-2012, 09:02 PM   #7
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Excellent idea!
I did the same thing.
sublime2 is offline   Reply With Quote
Old 10-22-2012, 09:49 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
If you did it was absolutely wrong.
Code minimum should even satisfy this requirement.
The Following User Says Thank You to Speedy Petey For This Useful Post:
electures (10-23-2012)
Old 10-22-2012, 09:53 PM   #9
joed's Avatar
Rewards Points: 12,904
I don't know where you read that they should not go under windows. They should not go over electric baseboards, there is no issue under windows.
That is the reason for code requiring them within 6 feet of doors and every 12 feet minimum. Since most devices have a 6 foot cord if you put in the center of the 12 foot spacing it will be 6 feet from a receptacle. But that is minimum. You add as many more as like. Every foot if you like.
Old 10-22-2012, 09:54 PM   #10
Missouri Bound's Avatar
Originally Posted by Fix'n it;1036034[B
]wow. i read on here that they should not go under windows.[/B]
Yeah....this is a DIY forum...sometimes you just have to wade through all of the bull to get the correct answer.
Do you want it your way or the right way?
Old 10-23-2012, 07:09 AM   #11
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
One problem here is people confuse post count with actual experience and knowledge. We have a good group of professional electricians here. Check profiles and make sure they are qualified. No profile probabely means no qualifications. Buyer beware!!
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
jbfan (10-23-2012)
Old 10-23-2012, 09:03 AM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Naw....that would never happen here......and I would never post just to pad my count.....nope, not me...
ddawg16 is online now   Reply With Quote
Old 10-23-2012, 10:04 AM   #13
electures's Avatar
Neither would I. Hehe
Old 10-23-2012, 07:51 PM   #14
Rewards Points: 236
ok, thanx, guys
Old 10-24-2012, 05:50 PM   #15
Rewards Points: 266
Under windows and between closely-spaced doors are the best places for an outlet that you want to be impossible to be blocked with furniture.
ionized is offline   Reply With Quote
Advice for replacing windows with French doors? John- Windows and Doors 6 05-29-2012 03:00 PM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 09:45 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Code requirements for outlet placement WillK Electrical 8 11-30-2010 08:16 PM
outlet height beneath large casement windows DangerMouse Electrical 3 07-29-2008 02:09 PM
