Outlets For A Tennis Court - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 01:02 AM   #1
Outlets for a Tennis Court
I am working on a tennis court where the owner wants to add outlets at each of the eight lights to supply as much power as possible for when they use the court for functions other than tennis. They also want the lights off when they are using the outlets.
The court has eight lights divided into two 30 amp 240 volt circuits. The lights are turned on by a single switch that controls a relay with four sets of contacts. The power runs from the panel and the 30 amp breakers to the relay and then splits off to the two end poles on each side. From there wire is run in conduit to the other three poles on each side(one circuit breaker covers one side of the court and the second breaker for the other side).
I know that I can not put an outlet on one leg of the breaker so I think I need to add a sub panel at the first pole with a 20 amp breaker. This would connect to one leg of the 240V 30 A circuit. And do this for each leg of the two 30 amp breakers. There will also be a switch at each pole to disconnect power to the lights.
So:
1) Will this work and be legal?
2) Could I have two 20 amp breakers for each 30 amp leg?
3) What type of panel could I use that would be exposed to the elements?
Thanks for taking the time to read this post.
Dclark is offline   Reply With Quote
Old 07-17-2012, 01:24 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you don't know these answers, why are you doing electrical work for someone else?
Have the owner call an electrician.
The Following 4 Users Say Thank You to k_buz For This Useful Post:
darren (07-17-2012), jbfan (07-17-2012), Speedy Petey (07-17-2012), stickboy1375 (07-17-2012)
Old 07-17-2012, 05:41 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
People just don't understand the concept of DIY means at your OWN residence.
My question is, is there no thought process of the consequences if someone gets injured or killed?
The Following User Says Thank You to stickboy1375 For This Useful Post:
J. V. (07-17-2012)
Old 07-17-2012, 07:28 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Originally Posted by k_buz View Post
if you don't know these answers, why are you doing electrical work for someone else?
+1 !!!!
Speedy Petey is online now   Reply With Quote
Old 07-17-2012, 08:44 AM   #5
joed's Avatar
Rewards Points: 12,032
There is much more to this than you think. 240volt lights means you do not have a neutral for the 120. You need to pull more wires. Might as well pull a proper circuit for the receptacles separate from the lights.
The Following User Says Thank You to joed For This Useful Post:
J. V. (07-17-2012)
Old 07-17-2012, 01:03 PM   #6
Thanks for the reply's, the owner is my brother and he is helping me out.
joed,
I thought there was a neutral because someone previously added outlets to each pole connecting to one leg of the 240. I just checked and they just used the ground for a neutral.
Old 07-17-2012, 01:37 PM   #7
" Euro " electrician
frenchelectrican's Avatar
joed,
The part I wrote the underline which this is very dangerous to do that.
I rather just run proper netural if you going to use the receptales ( this part it much wiser have electrican to assit you on that )
The other issue is that I know some tennis court they will direct bury the UF cable and will be very diffucutally to replace if you have this in conduit it may be a doable depending on the condtion of exsting conduits.
Otherwise you will have to bury a seperated conduit if the oringal one is too small to add a proper circuit.
Merci,
Marc
Old 07-17-2012, 01:48 PM   #8
Oh that's wonderful. I guess they did not like many of their guests. Maybe they wanted to kill them off one by one.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (07-17-2012), jbfan (07-17-2012), stickboy1375 (07-17-2012)
Old 07-17-2012, 01:53 PM   #9
Thanks alot Pete ! ( French cussing ) I have to clean my keyboard I own ya one
Merci,
Marc
Old 07-18-2012, 12:18 PM   #10
Thanks for the info, a neutral will be pulled if it can, if not then we quit. How high above the ground does the subpanel need to be and is a grounding rod required?
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 03:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 09:49 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
Need advice about tennis court lights bonedoc Electrical 2 08-28-2007 04:15 PM
