-   -   Outlets and switches in series or parallel? (http://www.diychatroom.com/f18/outlets-switches-series-parallel-110374/)
Tetranitrate 07-11-2011 11:52 AM
I will be installing some new work outlets and switches, and am wondering what the optimal way to lay out the wire path in the wall.
Are there any rules of thumb, when deciding how to wire up sockets and switches? Should I try and daisy chain (series) them as much as possible, or use a junction box in the attic, and have a few individual branches (parallel), or there is really no difference and I should just do whatever is easiest/cleanest/ or uses the least wire?
a7ecorsair 07-11-2011 01:12 PM
Do what fits the structure design. All wiring is in parallel whether you use a junction box or daisy chain from box to box.
AllanJ 07-11-2011 02:02 PM
Normal daisy chaining of outlets is really a parallel connection also. (connect blacks together and connect to one side, as in left or right, of receptacle, connect whites together and to other side of receptacle)
joed 07-11-2011 02:18 PM
Which ever method uses the least cable is the one I use.
There is no best or better way if you do it to code.
Tetranitrate 07-11-2011 02:35 PM
Thanks for the great replies everyone :thumbup:
I know that everything is technically in parallel, and should probably have chosen my wording a bit better (after all, being technically correct is the best kind of being correct), but I figured they were the easiest terms I could use to describe the setup I was asking about.
It is also good to know that there is no real preferred setup, it will make my work much easier. I figured someone might have had an opinion on it (ex: Do whatever uses the least wire, while not over-stuffing the boxes), and wanted to see what the general consensus was before jumping in.
