#1 |
Outlets quit working
Half my Electrical outlets and lights stopped working all of a sudden and a couple will sometimes come on randomly? I replaced the circuit breakers that provide power to the lights but that didn't change anything.
I have a dimmer on the dining room light (which it and the florescent kitchen overhead light are the ones that will come on suddenly and then go out). I turned on the porch light and when the dining room light WAS on, it noticeably dimmed. Is this weird or what? I can't figure it out. I have tried to test this switch with a circuit tester but the wires go into the case and none are exposed to touch with the probes. Could this dimmer stop everything else? If not what could be my problem.... help!!!!
#2 |
Average Joe/ex-Navy IC3
Lose connection somewhere.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| Tags |
light suddenly stopped, outlets suddenly stopped ![]() |
| Display Modes | |
| outlets in garage and exterior outlet stopped working | littleturley99 | Electrical | 16 | 07-10-2011 11:08 PM |
| Water Heater quit working!!! | MikeVila | Plumbing | 19 | 12-28-2010 12:43 PM |
| Water dispenser quit working | carpenter377 | Appliances | 0 | 12-26-2009 03:39 AM |
| Outlets not working after bad cord | faromic | Electrical | 5 | 12-24-2009 05:24 PM |
| Outlets stopped working | RammsteinNicCage | Electrical | 12 | 05-03-2009 10:47 PM |
