Outlets, Plugs And Connectors For Syncrowave 250 Welder - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 01:05 PM   #1
Rewards Points: 14
outlets, plugs and connectors for Syncrowave 250 welder
Hi, I was wondering about wiring up my new Syncrowave 250 when I came across Stubbie's article from way back in 2007:
http://www.diychatroom.com/f18/mille...allation-15306
It was excellent info on almost all I needed to know but I have and one additional requirement: I would like to be able routinely plug/unplug the welder and move it to a construction site.
So, I would need an outlet in both my garage and at the site. I would need a plug at the end of the welder input power, then I would need one plug and one "connector" at the ends of a 6/2 extension cord.
I've been accustomed to just using twist-lock type components for things like this, but they only go up to 50A. I beleive I need components that can take 120A. Or am I mistaken? So what parts am I looking for? Or is this a dream for only the wealthy?
(P.S. Although the welder output can go up to 310A, I will probably never set it to more than 160A at the site. In the garage I will probably never go over 210A.)
zoltan is offline   Reply With Quote
Old 10-24-2010, 02:21 PM   #2
I=E/R
a7ecorsair's Avatar
Your welder should have a manufacturers tags stating the power requirements.
a7ecorsair is offline   Reply With Quote
Old 10-24-2010, 03:12 PM   #3
Rewards Points: 14
I have to use #6 wire protected by a 125A breaker. I'm assuming the plugs and receptacles need not handle any more current than the #6 wire, but I can't find any twist-locks that go up that high.
Old 10-25-2010, 11:55 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,990
Take a look at Meltric Decontactor connectors. They are specifically intended for these types of applications. They're great. They're also insanely expensive.
Another option is to use Camlock connectors. These are single-pole connectors that are similar to standard welding cable connectors, but are intended for line voltage use. They are common in theatrical lighting and sound work.
mpoulton is offline   Reply With Quote
Old 10-25-2010, 04:38 PM   #5
Rewards Points: 14
Meltric is the clue I needed. Ebay has nearly 200 offerings. Thanks MPoulton.
