Old 06-25-2008, 06:25 PM   #1
Outlets Out, but....
Greetings--
Just got home and was informed that the plugs in the bathroom werent working. Light hairdryer ect dont work when plugged in. They work in other plugs.
No tripped breakers. No tripped GFI anywhere in there or the house.
What about this-- any suggestions ?
Piney is offline   Reply With Quote
Old 06-25-2008, 09:07 PM   #2
Licensed Electrician
jrclen's Avatar
Originally Posted by Piney View Post
Greetings--
In order of likelihood:
tripped GFCI
tripped circuit breaker
faulty GFCI
faulty connection in the circuit
Do you know where the GFCI for that circuit is located? Does it have power?
Did you turn each circuit breaker all the way off and then back on?
Do you know which circuit this is on and whether any other outlets or lights on that circuit are working?
John
jrclen is offline   Reply With Quote
Old 06-26-2008, 09:37 AM   #3
joed's Avatar
Tripped GFCI is the most comomn cause. If house is built before mid 80s then look in garage, outside, other bathrooms, basement. Most of the time is is found inthe garage behind the pile of stuff that never gets moved or the beer fridge.
Old 07-05-2008, 03:35 AM   #4
When was your house built? Sounds like aluminum wiring...or maybe push in terminals on a receptacle.
rgsgww is offline   Reply With Quote
Old 07-05-2008, 10:48 AM   #5
Built in the 90s. No Al wiring. All of the sockets and switches I've seen al use screw terminals.
*shrugs*
Old 07-05-2008, 11:07 AM   #6
Electrician
Greetings--
Recheck the breakers, I've been on more service calls for tripped breakers, and everyone always insist its not tripped.
But, i'm still going for a tripped GFCI.
chris75 is offline   Reply With Quote
Old 07-05-2008, 01:57 PM   #7
*shrugs*
Check for a gfci on the circuit. Try to replace the circuit breaker, sometimes those die. Check for loose connections in pigtails and terminals along that circuit. Check for a loose connection on the common, and hot connection at the common bus and the breaker.
When replacing circuit breakers you can do it while the main is on, im not sure how yours is like....If you do it while its on then please switch the breaker to an off position. Most breakers wiggle out.
Question about wiring outlets together firemanpato Electrical 5 01-05-2008 04:52 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 10:31 AM
