Old 08-09-2011, 10:30 PM   #1
Outlets on opposite sides of a wall: distance from stud face
I looked at this after hooking it up and had a couple of questions. These outlets are on opposite sides of the wall. Is there enough clearance from the back of the box and the stud face? Is it ok to run the cables down the stud side by side?
toobhed is offline   Reply With Quote
Old 08-09-2011, 10:49 PM   #2
Usually the wires can be stacked. The wires need to be fastened 1-1/4 inches at least from the stud faces.
But the wires go into the box via the usual holes even if the wires are less than 1-1/4 inches from the stud face at the point of entry.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 08-09-2011, 10:58 PM   #3
Lic Electrical Inspector
electures's Avatar
Looks fine. Add staples within 8" of top and bottom of all boxes. I don't like devices installed for rough inspection. Leave out so inspector can see splices.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 08-10-2011, 11:42 PM   #4
First, thanks for the helpful replies.
Oh man, I was hoping I could install everything and just pull it out.
I tried a stacker, is it ok that the wires are more loose than when they are stapled down. Does this meet the requirement for stapling within 12" of the box?
Old 08-11-2011, 07:12 AM   #5
Lic Elect/Inspector/CPO
Stackers are acceptable
NJMarine is offline   Reply With Quote
Old 08-11-2011, 08:34 AM   #6
Most ordinary staples can hold two 14-2 or 12-2 cables stacked, saving special stacker brackets and their expense for places where there are more or fatter cables.
When a cable goes through a hole drilled in a stud, that counts as a support.
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 11:08 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Carpentry 5 04-13-2009 11:23 PM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Plumbing 2 04-13-2009 10:54 AM
Type of box / how to feed power for in (face of) cabinet outlets? jamiedolan Electrical 2 03-19-2009 12:13 AM
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
