Outlets Not Working - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 01:27 PM   #16
Columbia, Mo.
mackelroy is offline   Reply With Quote
Old 01-17-2011, 04:50 PM   #17
rditz's Avatar
so have you tried the plug in tester in all outlets (top and bottom)??
next thing i might try is to shut the breaker off, remove the outlets and and use an ohm meter from box to box. first make sure everything is dead, then i would start at the end, tie white and black together, then go to the plug next in line and measure ohms across black and white. you should get 0 ohms, if you don't then you have a problem between the two boxes. if you find such a thing, then i would tie black to ground and retry measurement. if you get 0 ohms, then your problem is the white wire is broken.
repeat for each wire between boxes.
rod
rditz is offline   Reply With Quote
Old 01-17-2011, 04:54 PM   #18
Yes. I've tried it in all outlets, top and bottom. Will try your latest suggestion next.
Old 01-17-2011, 04:56 PM   #19
rditz's Avatar
just make sure that the wires are dead before you start tieing wires together
Old 01-17-2011, 10:22 PM   #20
I'd look at nearest switch that could be in series after working outlets. See if any wiring got loose from vibration or from switch use.
diyorpay is offline   Reply With Quote
Light switches not working but outlets are Jennybird Electrical 4 11-04-2010 10:15 AM
Outdoor outlets DIY_JC Electrical 8 08-09-2009 07:12 PM
Replaced outlets, now wall switches don't work? PittsburghPaul Electrical 3 08-09-2009 05:50 PM
some outlets not working Clallen Electrical 5 06-08-2009 04:09 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 07:28 PM
