Outlets Not Working - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 06:17 PM   #16
ok thanks in phase. im not worried about that right now. it's only temp til i get my URD to run to the house. generator is so i could power the lights and outlets so i can get the concrete poured in there
Tradesman14 is offline   Reply With Quote
Old 06-28-2009, 06:18 PM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Originally Posted by InPhase277 View Post
Sigh....
In my neck of the woods, this is what we call a cluster f*ck and a fire hazard.
Mine too. Thats right, we are in the same neck of the woods.
Old 06-28-2009, 06:20 PM   #18
what back feeding from a generator?
Old 06-28-2009, 06:39 PM   #19
". . .A confusing or chaotic situation or event, often caused by a failure of communication, an excessive amount of people attempting to accomplish a given task, or a complex environment."
Old 06-28-2009, 08:25 PM   #20
So right now the ONLY power in the barn is from the generator?
No other feed from the house/power grid?
What kind of panel? 240v? 2 hot feeds?
What wattage size is your generator?
A 5500w generator will put out about 23a @240v
My generator has a plug for 240v 20a output
Connecting 14a wire - HOT & NEUTRAL WILL NOT work
--well it will - but its a hack & will only give you 15a 120v & power 1/2 the panel.
I'd use #10 wire as a Temp setup & 20a 240v breaker
DISCONNECT BEFORE POWER from grid goes in
My gen also has "circuit breakers" of sorts
If you try to draw too much power you will kick out the breaker on the generator
VERY possible this happened
How far was the run with the #14g 15a ?
Old 06-28-2009, 08:41 PM   #21
2 fingered typer
woodnthings's Avatar
Why mess with the panel?
Just run some 14/2 wire from your lights and plug them into the outlets on the generator. Extension cords can do the rest. DO NOT RUN THE GENERATOR INDOORS! bill
woodnthings is offline   Reply With Quote
Old 06-28-2009, 09:06 PM   #22
kbsparky's Avatar
Sounds like you tripped one of the breakers on the generator to me....
-KB
Old 06-28-2009, 10:56 PM   #23
Sorry. If you don't know what your generator voltage is there is nothing anybody can do for you.
220/221 is offline   Reply With Quote
Old 06-28-2009, 11:07 PM   #24
the generator has 2 20 amps plugs im gonna run ten gauge with male plug into generator then hook the hot and neutral into the main breaker. its a 240 sinle phase panel. this is just temp. the generator is placed 25 feet from the barn. if i do what i just said will this power both sides of the panel..
Old 06-28-2009, 11:14 PM   #25
If you are talking about a standard 20 amp 120V recep on the generator, you will have to run the hot leg to both phases of the panel.
If it has a main breaker, run the hot wire to one lug and put a short jumper to the other one.
If it has only main lugs, do the same thing.
Be careful dude. You are scaring me
Old 06-28-2009, 11:27 PM   #26
thanks 220/221. remember now im only 17, but my rough in passed inspection. i work for a electrical contractor so im gonna have my boss come check out what i got... now what do u mean a jumper?
Old 06-28-2009, 11:40 PM   #27
Jumper = short piece of wire (jumping from one lug to the other)
And I know you are a yopundster. That's why I said BE CAREFUL!!
Old 06-29-2009, 12:13 AM   #28
OK thanks explain exactly how to do the jumper and wat to do and all. sorry but i dont want to mess anything up
Old 06-29-2009, 09:45 AM   #29
Especially yourself; look up arc-flash.
Old 06-29-2009, 05:49 PM   #30
Ok, now yur gettin on my nerves
I did explain how to do it and it's time for you to sink or swim.
Look at the panel, look at the breakers, read my instructions and figure it out.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
some outlets not working Clallen Electrical 5 06-08-2009 04:09 PM
Outlets stopped working RammsteinNicCage Electrical 12 05-03-2009 09:47 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Electrical storm - outlets not working SG94 Electrical 4 04-27-2008 09:28 AM
