Outlets And Lights On The Same Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 12:04 PM   #1
Rewards Points: 1,062
Question
outlets and lights on the same circuit
is this generally a bad practice?
Old 07-13-2011, 12:10 PM   #2
Mad Scientist
Generally, no, no problem with it. No code against it in the US, anyway. Though I do like to put garage/workshop outlets and lights on separate circuits so you're not left in the dark if a tool trips a breaker.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
amakarevic (07-13-2011)
Old 07-13-2011, 12:27 PM   #3
however, i was told to have bathroom/toilet outlets on a circuit of their own because a blow dryer can use too many amps.
Old 07-13-2011, 12:29 PM   #4
Mad Scientist
Right, and bathrooms require their own dedicated 20A circuit for outlets. I'm a little fuzzy on the exact requirements for bathrooms, but I do know their circuits can't be shared with anything that isn't in a bathroom.
Old 07-13-2011, 01:45 PM   #5
Licensed Pro
Bathroom receptacles have to be fed from a 20A circuit using 12ga wire. You may share that circuit with other bathrooms as long as you only have receptacles on the circuit. You may also have everything in one bathroom on the same 20A circuit, but it must feed only that bathroom.
My typical setup: masterbath gets at least one dedicated 20A circuit for the receptacles, more if it's a big bathroom, lights on a separate circuit (15A).
Smaller full baths may share a receptacle circuit if panel space is tight, but prefer individual circuits for each, lights separate (15A)
Half bath gets one circuit for receptacle and lights/vent. .
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
Can I use lights and outlets on same circuit? heyd Electrical 4 08-24-2010 12:05 PM
All the lights and Outlets on one Breaker? jonathan03 Electrical 7 03-15-2010 12:30 PM
Lights on circuit with outlets Klawman Electrical 16 02-22-2010 06:51 AM
How many lights on a circuit? How many outlets? helpless handyman Electrical 4 04-14-2008 12:11 PM
