Old 06-04-2012, 07:38 PM   #1
Topic Hunter
Focker's Avatar
Outlets Have No Screw Terminals
I'm helping my father-in-law install an under cabinet light. We're tapping into an existing outlet for the power source and the only available terminals are the push in type. There are no screw terminals whatsoever except for the ground. The outlet has 4 push in holes for the common and 4 for the hot. The house was built in 1995.
Should we replace the outlet or just push our new wire into the extra holes?
Sent from my mobile using DIY chat room app.
Focker is offline   Reply With Quote
Old 06-04-2012, 07:44 PM   #2
Replace it, one less thing to fail later on.
Old 06-04-2012, 07:54 PM   #3
Are there smaller screws that activate clamping plates inside used to hold the wires in the holes they can be pushed into? This kind of receptacle or switch is just as good as the screw terminal kind.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-04-2012, 08:30 PM   #4
Topic Hunter
Focker's Avatar
No screws anywhere other than the ground. 2 holes on left and 2 on the right for both the upper and lower sockets for a total of 8 holes and 1 ground screw.
Old 06-04-2012, 08:30 PM   #5
Master Electrician
Is this a kitchen countertop recep?
brric is offline   Reply With Quote
Old 06-04-2012, 08:35 PM   #6
Topic Hunter
Focker's Avatar
Yes it is.
Old 06-04-2012, 08:58 PM   #7
Master Electrician
Originally Posted by Focker View Post
Yes it is.
Then you will be creating an NEC Code violation by using that power for a light.
The Following User Says Thank You to brric For This Useful Post:
Focker (06-04-2012)
Old 06-04-2012, 09:13 PM   #8
Electrical Contractor
kbsparky's Avatar
Yes it is.
Are you in Canada? It's not likely that a 12 gauge circuit is connected to any back-stabbed outlet in the US ....
-KB
Old 06-04-2012, 09:42 PM   #9
Topic Hunter
Focker's Avatar
Just for knowledge sake can you elaborate on why it's a violation? Where is a more suitable power source? That same circuit also supports a dinning room and back patio outlet.
The house is located in Washington.
Old 06-04-2012, 09:51 PM   #10
kbsparky's Avatar
Back-stab holes in receptacles are only compatible with #14 gauge wire. If your counter-top outlets are back-stabbed, then the wire used is too small for the required 20 Amp circuit.
You may have an older receptacle device which has the larger holes for #12 wire, but those have been outlawed for many years now.
I'd replace the device in any case.
The other problem is you are not allowed to install any lighting on the small appliance circuits required to serve kitchen counter areas. There is a back-door loophole, but that requires an additional outlet to be installed, and a cord-and-plug connected light.
Stupid, but that's the way they wrote the Code.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Focker (06-04-2012)
Old 06-04-2012, 09:59 PM   #11
kevinp22's Avatar
its not that its per se dangerous but the two kitchen small appliance circuits have enough demand on them without adding lighting. plus kitchen lights wired on the fridge, microwave etc dont perform well - dimming when something comes on.
these circuits can serve the dining room, breakfast room, pantry, etc but not a back patio under current code. might have been okay when the house was built.
better source is whatever circuit is running the kitchen or dining room lights
kevinp22 is offline   Reply With Quote
The Following User Says Thank You to kevinp22 For This Useful Post:
Focker (06-04-2012)
Old 06-04-2012, 10:16 PM   #12
Topic Hunter
Focker's Avatar
Thanks guys... I'll pull from another source.
We want to hard wire these lights (which are LED's by the way, four 10.9 watt sticks) to on off switch.
Also I'm using 12 2 wire... No issues there right?
Old 06-04-2012, 10:23 PM   #13
kevinp22's Avatar
Sounds good. Best of luck
Hilti SMD57 Screw Gun Attachment Sierevello Building & Construction 2 12-30-2011 10:52 PM
Replacing old outlets (grounded vs none) Sonya_ Electrical 14 10-08-2011 12:37 AM
Burned out outlets - are we in danger of a fire? (Question 1) ChrisJJ Electrical 2 06-09-2011 03:55 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 09:49 PM
Receptacle screw terminals DIYGST Electrical 4 01-03-2009 08:34 PM
