Outlets Have No Screw Terminals
I'm helping my father-in-law install an under cabinet light. We're tapping into an existing outlet for the power source and the only available terminals are the push in type. There are no screw terminals whatsoever except for the ground. The outlet has 4 push in holes for the common and 4 for the hot. The house was built in 1995.
Should we replace the outlet or just push our new wire into the extra holes? Sent from my mobile using DIY chat room app. |
Replace it, one less thing to fail later on.
Are there smaller screws that activate clamping plates inside used to hold the wires in the holes they can be pushed into? This kind of receptacle or switch is just as good as the screw terminal kind.
No screws anywhere other than the ground. 2 holes on left and 2 on the right for both the upper and lower sockets for a total of 8 holes and 1 ground screw.
Is this a kitchen countertop recep?
Just for knowledge sake can you elaborate on why it's a violation? Where is a more suitable power source? That same circuit also supports a dinning room and back patio outlet.
The house is located in Washington. |
Back-stab holes in receptacles are only compatible with #14 gauge wire. If your counter-top outlets are back-stabbed, then the wire used is too small for the required 20 Amp circuit.
You may have an older receptacle device which has the larger holes for #12 wire, but those have been outlawed for many years now. I'd replace the device in any case. The other problem is you are not allowed to install any lighting on the small appliance circuits required to serve kitchen counter areas. There is a back-door loophole, but that requires an additional outlet to be installed, and a cord-and-plug connected light. Stupid, but that's the way they wrote the Code. |
these circuits can serve the dining room, breakfast room, pantry, etc but not a back patio under current code. might have been okay when the house was built. better source is whatever circuit is running the kitchen or dining room lights |
Thanks guys... I'll pull from another source.
We want to hard wire these lights (which are LED's by the way, four 10.9 watt sticks) to on off switch. Also I'm using 12 2 wire... No issues there right? |
Sounds good. Best of luck
| All times are GMT -4. The time now is 08:44 AM. |
