Outlets With Ground Up - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 07:25 AM   #1
Rewards Points: 1,216
Outlets with ground up
Ever see outlets installed with the ground up? I have and asked an electrician years ago why, he told me the reason but I forget, can any sparks out there give a reason why?
COLDIRON is offline   Reply With Quote
Old 12-05-2010, 07:53 AM   #2
yes, its common, we do it a lot in commercial depends on what is spec'd. the idea behind it is, if you have something plugged in and it comes loose gravity pulls the the cord down then the ground pin is exposed first.
dhubz is offline   Reply With Quote
Old 12-05-2010, 08:02 AM   #3
Several schools of thought, but both are correct, up or down. With it up, some suggest that anything falling down would not touch hot/neutral, this is good. Some also say that if the above happens and the cord sags, the ground connection is the first to be broken, not good. With the ground pin down, the ground is the last connection to be broken, good. As suggested above, depends on how it is spec'ed.
Old 12-05-2010, 09:49 AM   #4
Thanks to all.
Old 12-05-2010, 10:33 AM   #5
the Musigician
DangerMouse's Avatar
We've had this debate in other threads here many times.
The jury is still out on this one, evidently.
All of mine are ground down, it just 'feels/looks' right to me. lol
DM
Old 12-05-2010, 10:39 AM   #6
Electrical Contractor
kbsparky's Avatar
Some houses have the switched outlets installed opposite from the rest -- the ground up outlets are easily identified as the one controlled by a wall switch.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
DangerMouse (12-05-2010)
Old 12-05-2010, 10:52 AM   #7
the Musigician
Huh.... never seen that before.
But then again, I've never had switched outlets in any place I've lived.
Good info!
DM
Old 12-05-2010, 11:24 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I always put them ground down. All right angle plugs have the ground pin down, plug one into a receptacle with the ground up and the cord sticks up in the air.
Coastal South Carolina
Old 12-05-2010, 11:28 AM   #9
Rewards Points: 80
Years ago an alien space ship landed in New Jersey. Thats when it started. Some insist on December 21, 2012, all receptacles will automatically reverse there position.
Old 12-05-2010, 11:37 AM   #10
the Musigician
Hmmmm.... sounds a lot like Congress!
DM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
Lost my Ground jodywoj Electrical 10 12-20-2009 07:37 PM
1990 Bounder Motorhome 3 prong outlets actally have no ground connected!! Help! Holering Electrical 5 03-30-2009 01:59 PM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 02:50 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
