Outlets Connected To Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 03:13 PM   #1
Outlets connected to light switch
I have several outlets connected to a light switch. I'd like to remove a few from the loop and have them function like a normal outlet. Is this something as simple as removing a wire connection or is it more involved?
Thanks.
wcpatton is offline   Reply With Quote
Old 04-27-2011, 03:30 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
That depends on how the receptacles and switch are wired.
Give us details on the wires in the receptacle boxes and switch box.
Old 04-27-2011, 04:19 PM   #3
What you should do is open up the switch box and look at the wires. The wire going to the receptacle will be on one screw of the light switch find which one it is and cap it with the wire that provides power. Then you should be good for the receptacles always having power but the switch wouldn't control anything do you have a light?
jmans8666 is offline   Reply With Quote
Old 04-27-2011, 05:06 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
This will make all of the switched receptacle hot, the OP wants to change a "few". All depends on how it is wired.
Coastal South Carolina
Old 04-27-2011, 05:41 PM   #5
Oh I see I thought he wanted all of them hot
Old 04-27-2011, 05:47 PM   #6
A "Handy Husband"
rjniles's Avatar
To the OP, are both the top and bottom of the receptacle switched or just top or bottom?
Old 04-27-2011, 05:48 PM   #7
Licensed electrician
Rewards Points: 1,020
Depending on the room this affected it could also create a code violation by removing the switch cotrolled lighting outlet.
Old 04-27-2011, 05:49 PM   #8
There's no light connected to the switch currently; I use a floor lamp. Ideally, I would have the lamp connected to an outlet connected to the switch. The other 3 or 4 outlets would be regular "always on" outlets.
What do you need to know about the switch\outlets?
Old 04-27-2011, 05:56 PM   #9
Both are switched.
Old 04-27-2011, 07:55 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,858
Originally Posted by wcpatton View Post
Both are switched.
That makes it much harder. Pull one of the outlets out and see what wires are in the box. Are there any wires in the box that are not connected to the outlet? Is there an unused red wire? If not, then the best you can do without a lot of extra work will be to bypass the switch to make them all unswitched.
mpoulton is online now   Reply With Quote
Old 04-27-2011, 08:27 PM   #11
joed's Avatar
Rewards Points: 11,572
We need to know the wires in all the switched receptacles.
Old 04-27-2011, 08:45 PM   #12
You're going to have to pull new 3 wire from the switch to the receptacle
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 01:31 PM
Light will now switch off Manjo62 Electrical 3 02-10-2011 12:59 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
