Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 06:59 AM   #1
outlets
can you put outlets and switches on the same circuit
gdilis is offline   Reply With Quote
Old 12-12-2010, 07:05 AM   #2
yes.............but I suspect your question is too vague.
The Following User Says Thank You to Just Bill For This Useful Post:
Speedy Petey (12-12-2010)
Old 12-12-2010, 07:44 AM   #3
the Musigician
DangerMouse's Avatar
Yes, but I suspect Bill is correct.
DM
Old 12-12-2010, 11:02 AM   #4
Licensed electrician
Rewards Points: 1,622
There are certain circuits like kitchen small appliance circuits and laundry circuits that cannot have lighting on the same circuit as the receptacles. Depending on how many bathrooms the circuit serves there are also restrictions.
Old 12-12-2010, 11:57 AM   #5
closet switch
in a walk in closet where should the switch be inside the closet or outside of the closet by the door
Old 12-12-2010, 12:12 PM   #6
Master Electrician
Rewards Points: 3,870
Personal preference. The switch could be in another room if you want.
brric is online now   Reply With Quote
Old 12-12-2010, 12:34 PM   #7
Sounds like are you want to install a closet light to an existing branch circuit which has outlets already. This should be OK, but a few things need to checked first:
What does this branch circuit serve (bedrooms, bathroom, living room/den, etc.)? If the branch circuit serves a bathroom or kitchen, you should not add general lighting to it.
What is the rating of the breaker for this circuit, and what gauge of existing wiring serves the circuit? If it's a 20A breaker, it should be 12 AWG. 14 AWG should be used only on a 15A breaker. For your new wiring, you should stick to the same gauge as the rest of the branch.
What type of lighting fixture are you planning to put in the closet? If it is an incandescent fixture, it should be a recessed fixture with an integrated thermal cutoff to keep combustible materials in the closet (especially on the top shelves) from contacting the fixture.
The placement of the switch is your choice (within reason, of course; keep it away from water like sinks/bathtubs). I'd personally place it on the outside of the closet and use a pilot light switch that will indicate when the light inside is on.
clashley is offline   Reply With Quote
Old 12-12-2010, 12:51 PM   #8
There are strict clearance requirements for fixtures in closets. There are also restictions on fixture types.
Depending on the two items above you may not have the proper space to even intall a fixture in the closet.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Need to rewire outlets and lights..HELP suboveryde Electrical 1 11-02-2010 06:19 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
