Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 06:41 PM   #1
outlets
Can anyone tell me why manufacturer changed back wiring for outlets from 12 gauage to 14 gauge? It is so much faster to use back wiring and I can't find any outlets that have 12 gauge holes in the back!
bhawkin is offline   Reply With Quote
Old 10-18-2010, 06:54 PM   #2
Just call me Andrew
Rewards Points: 1,020
Backstab connections (the kind where you just push the wires in) are known to come loose over time. Don't use them....there are "backwire" outlets that go under a clamp you tighten with a screw - way easier than wrapping the wire around the screw and much more secure than backstabs.
Andrew
secutanudu is offline   Reply With Quote
Old 10-18-2010, 06:55 PM   #3
Licensed electrician
Rewards Points: 1,608
Back-stabbed devices are prohibited from use with #12 wire by the electrical code. You will not find any.
The reliability is less than devices properly wired to the screw terminals.
Old 10-18-2010, 07:12 PM   #4
Electrical Contractor
kbsparky's Avatar
They were changed due to too many burnouts and fires from marginal/bad connections.
UL was instrumental in making this change.
-KB
Old 10-18-2010, 08:55 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Get spec-grade back wired receptacles. The have a clamp for the wires where you stick the wires in the back and tighten the screw.
On second thought, these are about two dollars more each. If you are worried about the time it takes to make a proper connection on a receptacle I doubt you'd spend the extra $$.
Old 10-18-2010, 11:09 PM   #6
Thanx for the info guys! Very helpful. I have gone to several stores and no one could tell me "why" the recepts had changed. Knowing what I know now, it's worth the extra time to install them right! I will look into the "backwire" outlets and see if they are cost effective enough to out way the regular recepts that take a little more time to connect.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 07:28 PM
Power leading to outlets but no power ? s_anthony Electrical 22 01-05-2009 01:08 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
