Originally Posted by travesty
a7ecorsair, can you explain how an automotive trouble light would work?
frenchelectrican, for your test, you want me to turn off both breakers and then turn one back on and then confirm which outlets are on? What do you mean by interconnected circuit?
Oui please do turn of both breakers to confirm it.
then turn one back on either one to to see if that circuit is engeriszed.
The term of interconnected mean someone may hook up by mistake when someone done the wiring in the house most common is typically netural which I have see it from time to time but few case hot conductors as well if someone turn off more than just one breaker espcally when do major remodeling in the house.
and when someone reroute the cable or conductors it can get it mixed up by mistake.
Merci.
Marc
