Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2012, 10:04 PM   #1
Outlets
Only one outlet in my front room works tried changing the fuses and flipping the brakers and nothing can someone help
Adamsmami29 is offline   Reply With Quote
Old 05-22-2012, 10:23 PM   #2
Too Short? Cut it Again!
Have you checked them with an outlet tester? They are handy to have and only about $10-15. Get one that can test GCFI type outlets too.
Any chance the outlets are controlled by wall switches? This is not uncommon in living rooms.
Is there a GCFI protecting outlets in the room that might have tripped? Sometimes they are found in weird places. I lived in one place where some of the living room outlets were on the same circuit as the bath and the GCFI was in the bath. I found one set of family room outlets protected by an outdoor patio GCFI.
Old 05-22-2012, 10:40 PM   #3
Outlets
Yes we have one my husband got one and my brother in law checked it and said no electric was coming from the outlet
Old 05-22-2012, 10:42 PM   #4
It's a old house and we just bought it a few months ago and I checked the front room outlets only one works
Old 05-22-2012, 11:05 PM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Could be a receptacle somewhere that was backstabbed or a nicked wire broke and is breaking the connection. Removing and inspecting one receptacle at a time with the breaker off is where I would start.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-22-2012, 11:25 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You didn't happen to change a ceiling light fixture in that room did you?
The Following User Says Thank You to k_buz For This Useful Post:
andrew79 (05-23-2012)
Old 05-22-2012, 11:51 PM   #7
Loose hot or neutral wire a the box? Failed breaker switch?
Old 05-23-2012, 12:21 AM   #8
" Euro " electrician
frenchelectrican's Avatar
Do you have a switched receptale in there ? if so you may want to take look at the receptale itself and see what colour the conductor you have in there the normal unswitched verison will only have two conductor useally black et white.
The switched verison will useally have black et white et red so you know that is switched verison.
But the other common item will fail is splices on wirenuts or backstabbed recepatles.
Merci,
Marc
Old 05-23-2012, 07:15 AM   #9
dmxtothemax's Avatar
Rewards Points: 5,102
Have you got any gfci's anywhere in the house ?
Have you checked all recepticules for gfci's ?
You might have one somewhere and not know it !
dmxtothemax is offline   Reply With Quote
Old 05-23-2012, 07:21 AM   #10
Master Electrician
So the outlets worked when you bought the house or they've never worked? If they've never worked you could spend hours trying to figure out what the problem is. If they've stopped since you bought it the first place you should look is anywhere you've installed new electrical devices.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-23-2012, 07:29 AM   #11
Rewards Points: 1,294
do you have any switches on the walls that you don't know what they go to?
danpik is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 09:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 03:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 09:49 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
