Outlet Works But 3 Light Switches "die" After Turning Off - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 07:17 PM   #1
Outlet works but 3 light switches "die" after turning off
First of all, no changes have been made to the wiring in my house within the past 2 years.
In my bathroom the three light switches have stopped working ( one has a light over sink, second is a central light and a "fart" fan, third is light over the shower). Currently the outlet works. When i turn the breaker off the outlet looses power, and when the breaker is turned back on the lights will work until shut off for over 5 minutes (average, light switches must be "on" for the lights to power on when breaker is reset)
The breaker is not tripping, and from my voltage tester it seems like the light switches are not getting power after they stop working.
Prior to loosing power the energy saving bulbs would flicker when turned on starting about a week ago (all three switches have energy saving bulbs).
Any ideas what could be causing just the switches alone to "die"? I have tried all three switch without powering on the others and each one seems to be able to terminate the power and require a breaker reset.
Thanks in advance!
mors is offline   Reply With Quote
Old 10-26-2012, 07:46 PM   #2
Rewards Points: 78
I think you may be in the wrong place. Try www.diychatroom.com
Old 10-26-2012, 07:52 PM   #3
DIY staff
Rewards Points: 7,174
How have you tested the circuit?
Have you pulled the wires out of the box and inspected the wiring? Wire nuts tight?
Does the wiring to the switches run through an outlet first (pass throug) or possibly powered from the load side of a gfci outlet?
Did you use a tester from hot to neutral?
More details,Please.
Old 10-26-2012, 07:54 PM   #4
DIY staff
J.V.----Wake up--wake up---this IS DIY chatroom-----
Old 10-26-2012, 08:13 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Had a beer or many today John?
jbfan is online now   Reply With Quote
Old 10-26-2012, 08:54 PM   #6
joed's Avatar
Rewards Points: 11,986
Loose connection? Turn off the breaker and open the switch box and check all connections.
Old 10-27-2012, 12:10 AM   #7
dmxtothemax's Avatar
Rewards Points: 5,100
You most likely have a loose / dirty connecttion somewhere !
Could even be a bad breaker.
Could even be on the neutral side,
Even a faulty cable !
Start at the begining check undo and redo every join & connection.
dmxtothemax is offline   Reply With Quote
Old 10-27-2012, 02:49 AM   #8
To add another layer of confusion for me, the lights have started working today fter about 24 hours of not working (without a breaker reset) my wife noticed this first earlier today aftr turning the switches on by habit. I confirmed about 6 hours later by doing it myself out of habit.
I would have to say my wiring is possessed and its a good thing we are planning to sell!
Old 10-27-2012, 07:49 AM   #9
custom user
Rewards Points: 150
Loose and faulty connections often do work intermittently, no mystery there.
JasperST is offline   Reply With Quote
Old 11-10-2012, 12:35 PM   #10
Retired Electrician
Loose connections develop heat, heat may cause a fire! If you're selling it you will likely be on the hook for the repairs, if you knew they were required when you sold the place...If the wiring is aluminum, I would run far and run fast after you have a qualified electrician fix the stuff (aluminum wiring is not for a DIY'er)
Dave
FLICKER is offline   Reply With Quote
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 10:20 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Several Light Switches Don't Work? Help? Scorpion6 Electrical 4 10-10-2010 10:11 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
50+ year old home-all light switches one-way? mudpaw Electrical 13 06-22-2008 02:57 PM
