Outlet Wiring; Hidden Ground Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 12:00 PM   #1
Outlet wiring; hidden ground wires
Noobie question -- my apologies in advance.
I am trying to replace an outlet, which I have learned: 1) is part of a series wiring (i.e., connected to 3 other outlets, ugh!); 2) lives within a metal outlet box; 3) has ground wires that are hidden behind said metal outlet box. That is, I can see the ground wires, but they are tucked behind the outlet box, which keeps me from connecting the ground wires directly to the outlet.
I assume the person who wired this outlet intended to use the outlet box to ground the outlet. My question -- do I just ensure a connection or contact between the green ground screw on the outlet and the metal box? Is there a proper (or, maybe more importantly, improper) way to do this?
I understand that a parallel configuration would be superior, but I'm in an unfortunate situation of working with what I have. I have one outlet that appears to have failed, which has knocked out the 3 other outlets in the series. I tried replacing the outlet once before, and thought I had grounded the outlet by ensuring contact between the ground screw/terminal and the box, but after two weeks of working fine it failed again after plugging in a new appliance. I don't know if I ruined the outlet, or if it's just not properly wired/grounded. Any advice about ensuring a safe configuration is greatly appreciated.
Cahill_Main is offline   Reply With Quote
Old 11-26-2012, 12:33 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Not connecting the ground will not cause a receptacle to fail.
You have other issues.
All of your receptacles are wired in parallel anyway.
Old 11-26-2012, 05:33 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
A picture would help. You say the ground wires are tucked behind the box, are they wrapped around the cable sheathe and secured by the box clamp? This is called a "Boston back wrap" and was common in the NE in the 50's and into the 70's. I did tons of them working as a helper back in the late 50's.
As long as the cable clamp is secure it will adequately ground the box. You need a pigtail from a ground screw in the back of the box to the receptacle ground. It will not meet code today but it is a grandfathered method.
But as jbfan states, a bad ground is not your issue. Show us a picture.
Coastal South Carolina
Old 11-26-2012, 07:21 PM   #4
Rochsolid's Avatar
your plugs are wired in parallel, that being said, i think that your issue is in the plug, sounds like you have lost power at that plug, thus losing power to the other receptacles down stream.
Rochsolid is offline   Reply With Quote
Old 11-26-2012, 07:32 PM   #5
TTW
TTW's Avatar
What appliance did you plug in and did you buy a really cheap outlet?
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Tags
;electrical outlet box , ground contact , outlets , series circuit
Wiring Generator to Backfeed Breakers - Neutral and Ground Wires? tjnoff Electrical 84 12-09-2014 09:59 PM
Outlet wires in 1940's home are not color coded help. vash1012 Electrical 1 07-16-2012 11:14 PM
Open Ground in Non Daisy Chained Outlet Circuit RileyRR Electrical 2 05-18-2011 03:00 PM
Connecting ground to neutral in old 120v 2-prong outlet flow Electrical 15 11-08-2010 01:15 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
