Outlet Wiring Help Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 11:41 AM   #1
Hello,
I could use a little guidance in changing out an outlet in my home. I'm attaching several photos. The old outlet has two black wires, two white wires and a ground. I would like to swap it out for the new outlet that contains a built-in led light in place of one of the sockets. However, the new outlet only contains a black screw (for the black wire I imagine) a silver screw (for the white wire?) and a green one on top for the ground.
Is this as simple as combining the two black wires from the old and attaching it to the black screw? and likewise for the white one?
Thank you in advance,
Darin
http://www.flickr.com/photos/75840697@N03/
djcirello is offline   Reply With Quote
Old 02-03-2012, 11:48 AM   #2
Rewards Points: 150
Tie the black wires together with a pigtail to the receptacle. Same with the whites.
psilva8 is offline   Reply With Quote
Old 02-03-2012, 01:09 PM   #3
Thank you!
Rookie needs help wiring an outlet robmarston Electrical 7 10-16-2011 04:41 PM
Help wiring new outlet Wnt2bsleepin Electrical 15 09-08-2011 11:53 AM
Wiring Switched Outlet matt151617 Electrical 15 07-03-2011 01:16 PM
Wiring a new outlet advice kennykenny Electrical 19 08-29-2008 10:54 AM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 08:10 PM
