Outlet Wires In 1940's Home Are Not Color Coded Help. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 10:52 PM   #1
Outlet wires in 1940's home are not color coded help.
So I am trying to install a GFCI outlet in where a 2 prong outlet was in the house I just bought. I made the mistake of not noting where the wires were previously installed before I took the wires off the old outlet as I soon found out all the wires are black. There are 2 pairs of wires. I have determined which wire is hot and have connected that to the brass "line" screw. I connected the other wire in that pair to the silver "line" screw. What I need to know is for the wires that should connect to the "load" terminals, is there a way I can tell which wire should go where or does it not matter for the "load" terminal? None of them of course have power. If there is no way of telling them apart, then is there a danger in just guessing and seeing if it works or will the outlet just not work if the wires attached to the load terminal are mismatched?
Thanks in advance, I have been having so much trouble answering this question.
vash1012 is offline   Reply With Quote
Old 07-16-2012, 11:14 PM   #2
Master Electrician
You would need to go to the next device downstream amd test with power off and a continuity tester which one is hot and which one is neutral.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Power loss carlko Electrical 55 03-12-2011 06:26 PM
Replacing outlet with 5 wires PokerMunkee Electrical 4 09-12-2010 07:24 PM
220 outlet with alum wires Tony11657 Electrical 7 02-27-2009 11:21 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
