Outlet Weather Cover - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 11:27 AM   #1
outlet weather cover
Hey guys, new to the forum...im a contractor in florida and could use some help
i got an outdoor wall outlet that is flush with the new stucco that was applied (see below)
the city wants it covered with an outdoor weather cover, but the outlet is surrounded by stucco which makes this a tough situation. Can i somehow put a cover without having to drill around the outlet?
Thanks guys!
tbce is offline   Reply With Quote
Old 08-22-2012, 11:35 AM   #2
Rewards Points: 82
On each end is a screw hole. The trim plate holes will be on the GFCI receptacle itself. Find the two holes, install a cover. What kind of contractor are you?
That receptacle looks ruined anyway. Pull it out.
Old 08-22-2012, 12:11 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Looks like a very poor job of stucco, or planning for the electrical
jbfan is online now   Reply With Quote
Old 08-22-2012, 01:27 PM   #4
First remove that old, ruined receptacle.
Install one of these:
http://www.homedepot.com/Electrical-...1#.UDUVpaDYjKo
Then Install one of these:
http://www.intermatic.com/en/Product...se_Covers.aspx
Follow the directions or call an electrician.
parman is offline   Reply With Quote
Outdoor Outlet seansy59 Electrical 3 03-09-2012 04:50 PM
flush mount dryer outlet bryan1282 Electrical 8 10-01-2010 07:17 PM
Can I use a drywall patch to cover a hole where an old outlet box used to be stephroberson Drywall & Plaster 4 09-28-2010 08:25 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
