Outlet Trim Plate Spacer? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 01:39 PM   #16
Licensed electrician
Rewards Points: 1,630
I get a kick out of these posts. Someone comes here and asks a question and when they don't like the answer the people on the board are the ones with the wrong answer.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
jbfan (08-06-2012), stickboy1375 (08-06-2012)
Old 08-06-2012, 02:11 PM   #17
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Google extension ring for electrical boxes. Purchase one and then make your own spacer. The extension ring will have to increase the volume of the box enough to make it code legal for the box fill. A spacer by itself will not be compliant, the device and wiring must be contained within an approved enclosure.
If you can pull the switch out and get us some good pictures of the wiring and box size we can tell you the required cubic inces you will need to add.
Just trying to give world class customer service ....
Old 08-06-2012, 03:31 PM   #18
Here is another solution.
http://www.aifittings.com/catalog/mi...-extender/BES2
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 09:36 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
