Outlet With Swith And Older (White, Black, Red) Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-14-2009, 11:03 PM   #16
CaptChaos's Avatar
Hi Everyone:
Well, I'm all wrapped up and I feel quite good. The "only" thing left to do is patch the holes in the drywall. Thanks to everyone who's advice was so crucial. I hope I can return the favor some day (most likely in the distant future).
Cheers,
Cap'n
CaptChaos is offline   Reply With Quote
Old 09-14-2009, 11:03 PM   #17
Registered User
Termite's Avatar
Originally Posted by 4x42001 View Post
If you chose to have your lights in the bathroom GFCI protected,
then you are putting yourself in unnecessary danger.
You cannot be serious. Are you?
That's some major misinformation you're offering.
Old 09-14-2009, 11:15 PM   #18
CaptChaos's Avatar
PS: For what it's worth, I ended up wiring it as follows:
Hot wire coming in (the old black wire in the original post) is connected to two other wires -- one goes to a standalone (illuminated -- fancy) switch and goes out to the wire that goes to the ceiling light (old red wire in original post).
The other hotwire connection goes with the incoming neutral (old white wire) the GFI outlet with the two new wires to protect the other outlet.
All is well (I think).
Thanks again.
Old 09-14-2009, 11:17 PM   #19
CaptChaos's Avatar
I'm assuming based on the post that the danger referred to is if the GFI tripped and you were naked and without light in the shower...maybe true but better than electrocuted I would think.
