Outlet With A Switch On Top - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 05:23 PM   #1
Outlet with a switch on top
So this is my new project, i want to have an outlet, with a switch on top and a power outlet on the bottom. But generally the switch would control a light or fan, but i want it to control the outlet on the bottom. My father has been at it but can't figure it out. if anyone can tell me exactly how to do it, or point me where to find it, it would mean so much.
thanks in advance
GTAgeek is offline   Reply With Quote
Old 01-27-2009, 05:30 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You should have 2 brass screws on one side, one brass screw and one silver screw on the other. If you want the switch to control the outlet as well, you'll basically hook this up backwards. The side with the brass screw by itself is where you'll hook the line to(constant hot). White on the silver screw and your light on the side with the 2 brass screws.
PS. Don't break the tab between the 2 brass screws
wirenut1110 is offline   Reply With Quote
Old 01-27-2009, 09:40 PM   #3
Rewards Points: 6,652
Actually you have to break the tab, in order for the switch to control the outlet. Otherwise, it will not work. The way you hook up, is connect the white to the Silver, then connect a jumper between the switch screw, and the outlet screw. From there, the Black is connected at the switch. These switches come with directions to show you how to do it depending on the configuration that you wish.
Old 01-28-2009, 09:56 AM   #4
Rewards Points: 1,440
Another style:
Gold screw to receptacle and switch.
Gold screw to switch only.
Silver screw (for neutral).
To control the receptacle with the switch connect power to the gold screw for switch only.
To have the receptacle always live and use the switch for something else, connect power to the gold screw for receptacle and switch.,
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 07:25 PM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 09:08 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Outlet controlled by switch Shardi Electrical 4 10-09-2005 07:24 PM
