Old 02-24-2009, 09:22 PM   #1
Outlet / Switch
I need to remove an outlet from a light switch.
I need the outlet to be live all of the time, not just when the switch is in the on position. I have no money for an electrician, so I have to do it myself.
Does anyone know how to go about this?
Jannette63 is offline   Reply With Quote
Old 02-24-2009, 09:34 PM   #2
dSilanskas's Avatar
Outlet / Switch
Are you saying you want to install a plug off the light switch but have it constant powered?
dSilanskas is offline   Reply With Quote
Old 02-24-2009, 09:37 PM   #3
Outlet / Switch
Hi,
I have an electrical outlet that runs the garbage disposal, so it is hooked up to a light switch for power. The second outlet is also hooked up to the swith, so you only get power when the switch is on.
I want to make the second outlet to be live 24/7 leaving the top outlet connected to the switch.
Old 02-24-2009, 09:40 PM   #4
Outlet / Switch
Old 02-24-2009, 10:16 PM   #5
Outlet / Switch
Removing switch control from an entire existing receptacle (outlet, plug) making the latter live all the time.
Turn off the power. Open up the box containing the switch. Remove the switch from the box. Remove the two non-bare wires from the switch. (If there is a third, bare, wire, remove it from the switch also and put it inside along the side of the box connected to nothing.) Connect the two wires together (1). Close up the box (2).
Refinement (1) If one of the switch wires is short (is a pigtail) and connected to another wire nut, remove it completely. Connect the other switch wire to everything else under that wire nut.
Refinement (2) If you don't have a cover with no hole where the old switch was, put the old switch with nothing connected to it back into the box so the hole is filled.
If only two wires (one white, one black) come into the box with the duplex receptacle, it is not possible using the existing wires to make the bottom receptacle live all the time and the top receptacle stay switch controlled.
If power comes to the receptacle first and another cable goes to the switch further on, then you can do what you want. You will find the white (neutral) of the power feed connected to a silver screw of the receptacle. You will find the black (switched hot) of the switch loop cable connected to a gold screw of the receptacle. The other two wires (probably one white and one black) will be connected to each other with a wire nut and are always hot. You need to bend and snap off the little gold tab between the two gold screws. Connect a short (about 6 inch) black wire between the wire nut (with the existing wires still there) and the other gold screw of the receptacle.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 07:25 PM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 09:08 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Outlet controlled by switch Shardi Electrical 4 10-09-2005 07:24 PM
