Outlet Stopped Working Repeatedly - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2011, 06:47 PM   #1
Outlet stopped working repeatedly
An electrical outlet i have dies every time something is removed from a plug on the other side of the wall. My circuit breaker doesnt trip but the plug just dies and wont work until it gets replaced. Can anyone help?
Mebbid is offline   Reply With Quote
Old 04-24-2011, 08:03 PM   #2
Learning by Doing
Leah Frances's Avatar
You've got a loose connection somewhere. Do you know how to turn off ALL power to the circuit? Do you have a non-contact voltage tester?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-24-2011, 10:38 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
The loose connection is in the receptacle that has to have something plugged in.
Turn off the power, and replace the receptacle.
jbfan is online now   Reply With Quote
Old 04-25-2011, 08:06 AM   #4
Rewards Points: 1,536
Many loose connections develop where wires are pushed into holes in the back of switches and receptacles and just stick in place. Some receptacles have screw clamps for the holes in back which make the connections more reliable. If not, it is better to use the screws on the sides to hold the wires in place.
When two or three wires want to go under the same screw, cut a short (6" or so) length of wire (pigtail) of the same color and wire nut that to the other wires. Then connect the other end of the pigtail to the screw. The exception is if the wires, if not curled around the screw, are held in place by grooves or a retaining washer as opposed to just the tightness of the screw.
After removing the wires from the push in holes, you may notice the wire end nicked. If so, snip off the end and cut back the insulation to get a new bare wire end.
Outlet quit working? stevegilmo2004 Electrical 2 03-19-2011 10:22 PM
Septic pump stopped working after I unplugged it fixithelp Plumbing 5 03-18-2011 12:21 PM
Shower Lighting and fan stopped working (separate fixtures on same circuit) IndyNotHandy Electrical 15 03-15-2011 09:39 AM
Ice Maker stopped working Whirlpool ED5FHEXNQ00 Hotlatte Appliances 1 05-14-2009 03:15 PM
Whirlpool Icemaker Stopped Working jablizz General DIY Discussions 1 07-19-2008 08:38 PM
