-   -   Outlet stopped working repeatedly (http://www.diychatroom.com/f18/outlet-stopped-working-repeatedly-102589/)
Mebbid 04-24-2011 07:47 PM
An electrical outlet i have dies every time something is removed from a plug on the other side of the wall. My circuit breaker doesnt trip but the plug just dies and wont work until it gets replaced. Can anyone help?
Leah Frances 04-24-2011 09:03 PM
You've got a loose connection somewhere. Do you know how to turn off ALL power to the circuit? Do you have a non-contact voltage tester?
jbfan 04-24-2011 11:38 PM
The loose connection is in the receptacle that has to have something plugged in.
Turn off the power, and replace the receptacle.
AllanJ 04-25-2011 09:06 AM
Many loose connections develop where wires are pushed into holes in the back of switches and receptacles and just stick in place. Some receptacles have screw clamps for the holes in back which make the connections more reliable. If not, it is better to use the screws on the sides to hold the wires in place.
When two or three wires want to go under the same screw, cut a short (6" or so) length of wire (pigtail) of the same color and wire nut that to the other wires. Then connect the other end of the pigtail to the screw. The exception is if the wires, if not curled around the screw, are held in place by grooves or a retaining washer as opposed to just the tightness of the screw.
After removing the wires from the push in holes, you may notice the wire end nicked. If so, snip off the end and cut back the insulation to get a new bare wire end.
